the jelly belly build
Postby mikeschn » Sun Jul 15, 2007 7:59 pm
Whoda thunk it? :lol: :lol: :lol: At least he wasn't moving towards you!
angib wrote:
As in "Where the @<~# did that bus come from?"
Andrew
Postby asianflava » Sun Jul 15, 2007 9:23 pm
angib wrote: The person who drives into the back of you doesn't do so because they can't quite see your lights clearly enough. They do it because they're not paying attention. People drive into the back of trucks.....
That is so true, but I don't want to give them the opportunity to say, "One tail light must have been out because the ONE I saw wasn't lit." No one will admit that it was their fault even when it is. I'll nip the "I didn't see him" excuse right in the bud.
asianflava
Postby Nitetimes » Sun Jul 15, 2007 11:05 pm
asianflava wrote:That is so true, but I don't want to give them the opportunity to say, "One tail light must have been out because the ONE I saw wasn't lit." No one will admit that it was their fault even when it is. I'll nip the "I didn't see him" excuse right in the bud.
My thoughts exactly. Hence the reason for this. If you don't see that in front of you then you deserve it when I punch you in the head. 8)
Rich
- Thomas Jefferson -
Nitetimes
7000 Club
7000 Club
Images: 194
Postby doug hodder » Sun Jul 15, 2007 11:12 pm
Damn Rich...that paint came out really good!!!! doug :thumbsup: :thumbsup:
Postby Nitetimes » Sun Jul 15, 2007 11:34 pm
Thanks, it's not bad. Now I gotta get the fenders and tongue done to match.
Rich
Nitetimes
7000 Club
7000 Club
Images: 194
Postby del » Tue Jul 17, 2007 11:07 pm
For all of you worried about seeing only one tail light when following. I took this picture from 8' behind and as far over as the house would allow.
note a portion of the tail light is still showing. A safe following distance would give you a much better view of both tail lights (this one and the one yet to be installed).
del
del
5000 Club
5000 Club
Images: 410
Postby del » Sun Jul 22, 2007 12:15 am
Took time off to fix my brothers volvo (at least part of it). Started back on my tear, with cutting out for the other taillight.
Started to fit it, but not finished.
del
del
5000 Club
5000 Club
Images: 410
Postby del » Sat Jul 28, 2007 12:11 am
Roughed in the second taillight.
Had to take a break from fiberglass, been working on my subaru. The subaru looks cool with half a two inch lift under it.
del
del
5000 Club
5000 Club
Images: 410
Postby del » Sun Jul 29, 2007 12:51 am
Now both taillights are cut flush with the body. I am now working on the tag for the trailer.
Of course the tag will be turned around, after cutting out a recess.
del
del
5000 Club
5000 Club
Images: 410
Postby del » Mon Jul 30, 2007 10:51 pm
I finished one of my light modifications.
blue dots. Let us see when I get up the nerve to drill the other one. Already broke one tail light, and wally world only sells the complete assembly ($6 bucks shot down).
Fiberglassed around my non perfect seams (why I must paint). I like fiberglass (relativity) when you can add enough filler so it stays were you put, and does not run off.
del
ps now Aunti M's bubble level should hold till next time.
del
5000 Club
5000 Club
Images: 410
Postby angib » Tue Jul 31, 2007 11:17 am
del wrote:I finished one of my light modifications.
It's good to see a guy getting on with the really important stuff, and not wasting time on incidentals like the body........ :roll:
Andrew ;)
angib
5000 Club
5000 Club
Images: 231
lense hole
Postby S.A.Mike » Tue Jul 31, 2007 2:05 pm
howdy del on the subject of putting a hole in the plastic tail light lense you might try using a 1/2 inch drive socket...not sure of the size of your blue dot .Just use one that measures the same size of hole you need. Heat it pretty warm not too hot and use it to melt a hole.it has worked for me before.You may want to put the socket on an extension..no burn fingers that way.Also a peice of pipe or tubing will work.
Mike
S.A.Mike
Postby Miriam C. » Tue Jul 31, 2007 5:24 pm
:lol: 8) Thank you so much Del. Everytime I see that I wish I could get a closer look. All the pictures in the world won't fix that. Sure wish you would get to the hatch part so I can see... ;)
Postby del » Wed Aug 01, 2007 11:46 pm
Miriam C. wrote::lol: 8) Thank you so much Del. Everytime I see that I wish I could get a closer look. All the pictures in the world won't fix that. Sure wish you would get to the hatch part so I can see... ;)
Ah the hatch, soon. Have to study up on how Auntie M did hers first. True fully I need to do a little more fiberglass. Can only do so much in one session, than I work on
Andrew wrote:the really important stuff, and not wasting time on incidentals like the body........ :roll:
:lol: :lol: :lol:
del
ps I should be passing through Missouri in november, would be happy to swing by and let you look at the jelly belly. If you mapquest yakima wa (98901) and gibsonton fl I think I will be close.
del
5000 Club
5000 Club
Images: 410
Postby del » Thu Aug 02, 2007 11:41 pm
del wrote:I put on the other side lower skin.
I wish it had gone on like the other side! So hopefully I can fix the buckle after the glue dries, other wise run across the street, and across the churches field screaming.
del
Now is time to fix the buckle, it goes like this sand fill, next day sand and fill......
Repeat sand fill....
del
ps I am filling the low spots with fiberglass and a sandable filler, I know it is a weird purple color.
del
5000 Club
5000 Club
Images: 410
