bdosborn wrote:You know, I never see those on 120V wires. I bet Chuck would know why.
Yes, Joanne - That's the industry standard way of making connections with stranded wire to recepticales which aren't designed for stranded wireJoanne wrote:If you have the #10 wire in hand and want to use it, maybe you should consider buying crimp-on ring connecters and use them to attach to whatever plug or switch you need.
While it's true that the screws are designed not to back all the way out (strictly as a convenience to the user) it doesn't 'damage' the outlet (or the screw for that matter) in any way to remove and reinstall them using ring terminalsChuck Craven wrote:On duplex outlets the screws can’t be removed with out damaging the outlet
Chuck Craven wrote:On duplex outlets the screws can’t be removed with out damaging the outlet.
Chuck
I agree with you there . . . . but you can legally use clamp type outlets with stranded wire, can't you? No need for a ring terminal if all your outlets are of ther clamp type . . . . you just can't (legally) use stranded wire under a screw head, so on those types of outlets, you would need a ring terminalChuck Craven wrote:Will I guess the cheaper outlets you can get away with removing the screws. I normally use Hubble outlets, they rivet the clamp plate on the end of the screws. When you take out the screws the clamp plate breaks off
