benzu wrote:I bought the cd from Steve Frederick and it doesn't say how to attach the floor to the frame. I assuming I should use lag bolts counter sunk in the floor. Is this correct or is there another method.
Mike
benzu wrote:Thanks, Joanne
I'll check them out Ace today, yes I'm going through a metal frame, my steel frame is 1'' x 3'' x 1/8'' square tube. Hey another question I bought the roofing sealent for the floor and was wondering do I seal the underside only or do I seal the topside too.
mike
Airspeed wrote:I used carriage bolts with spiked carriage bolt washers. The washers have the square hole in the center and spikes like those on a tee nut to grip the plywood and spread the load of the bolt head.
They work great and when tightened they become nearly flush with the suface, you could coutersink the bolt head using a spade bit but do it before you drill the through hole.
Aaron
Dave Bob wrote:Find a Fastenal place nearby, they are a lot cheaper than the box stores for stainless.![]()
Dave
