63" wide
63" wide
Postby Southern Oregon Bob » Sat Mar 05, 2005 3:25 pm
I'm new to the forum and have already learned so much, but I have a few questions I'm anxious to resolve so I can get started on my first tear. I want to go a full 60" on the inside for a queen mattress. Thats going to put me over 60 for my top. So if I run my aluminum crossways on the top I'll have 2 joints. What is the best way to make those joints watertight and looking good. Can hardley wait to get started Bob
Southern Oregon Bob
Postby asianflava » Sat Mar 05, 2005 3:50 pm
Mine is 62 1/8 wide, the 5x5 birch I was using was actually 60 1/8 I didn't cut it to insure parallelism. I haven't gotten to the aluminum cladding yet but I plan on installing the seam the length of the trailer (along the top). There will be an extruded piece of aluminum to cover the seam. I am also thinking about putting the same extrusion on the sides, I like that look it breaks up the slab sided look.
asianflava
Postby madjack » Sat Mar 05, 2005 5:31 pm
...Bob, some commercial TD manufacturers do their 5 ft'rs that way, they simply overlap at a rib put a bead of "evil black stuff"(automotive windsheild sealant) between 'em and screw it down...works great for them and looks OK
madjack 8)
Postby SteveH » Sat Mar 05, 2005 5:36 pm
I think it's called urethane sealant. And, Jack is right, it is nasty, evil, gets every where on everything, and gasoline is the best solvent to get it off when it is still wet. When it's dry, a jack hammer is best. :lol:
SteveH
SteveH
Images: 42
Postby Doug » Sat Mar 05, 2005 6:46 pm
Be careful not to get any on your "hootus".
:lol:
Doug
Postby Southern Oregon Bob » Sat Mar 05, 2005 7:35 pm
Thanks for the quick replies. How about 54" tall. I can only find 4x10x3/4 in my area and I see a couple of boat builders on here making some pretty difficult joints. Can't I just butt joint 6" along the bottom with biscuts or dowels and then by the time I put in the bulkheads and 1x2 verticle bats along doors and where ever needed I would think that would be plenty strong? Any thoughts? Or do most people think they even need that extra head room. It seems tight when I add it all up, but I've never had the pleasure of sitting in one to see how it feels. Thanks again Bob
Southern Oregon Bob
Postby norm perkiss » Sun Mar 06, 2005 12:59 am
Southern Bob,
You can have the sheet metal supplier join the sheets of aluminum. They make a multi layer fold that is weather tight. I just picked up my alluminum with 2 seams that will run from side to side. There was no extra charge for the seams. Our Teardrop is 64" wide and I did not find any local metal suppliers this 5 foot plus wide sheets. I may have to be creative with the edge molding, a little extra caulking?
I also made the height about 54" tall. I routed a lap seam the length of the plywood. The 1x2s and lap seam tie it all together with plenty of screws and glue. The seam is along the bottom portion of the wall.
There is plenty of headroom and the 5'+ width is perfect for us. The profile is not the classic shape, it's a more rounded.
Good luck with the build.
Norm
norm perkiss
Images: 62
Postby Southern Oregon Bob » Sun Mar 06, 2005 12:16 pm
Off the top of my head the seams sounds better then "The Evil Black Stuff"
Thanks Bob
Southern Oregon Bob
