David Grason wrote:Thanx Steve. Yes, I could trim the aluminum to a rough shape using the metal shears. They do ok when there is good clearance on either side of the jaws. But when I run up against plywood on one side or the other, they quickly bind up. Usually ends up kinking the aluminum and fortunately, I should be able to cover those with moldings as I said before. (whewwwwww)
I think where I ran into problems with the laminate trimmer is when I tried to use the router in place of the shear. If I was cutting through virgin aluminum, the laminate bit was cutting on 180 degrees of it's circumfrance. On the other hand, if I can trim it in really close with something else, the laminate bit can pretty easily do the last shape up because it's only cutting on a very small fraction of its circumfrance. I think that's what I'm going to try next. I'll keep everyone aprised.
Still have no idea how to post pictures though.
Denny, I posted this reponse and then I saw where you had posted right ahead of me. Thank you. I didn't even think about turning the speed down. DOH!! My laminate trimmer is a Ridgid and it's got a speed control on it. Man, why didn't I think of that?
Also I got better results with my first bit. It's a flush cutter whereas my back-up bit cuts on a bevel. Do you reckon that has anything to do with it?
Denny Unfried wrote:One word of caution is you will want to protect the aluminum because the chips will get between it and the router and scratch it up badly.
David Grason wrote: On the other hand, if I can trim it in really close with something else, the laminate bit can pretty easily do the last shape up because it's only cutting on a very small fraction of its circumfrance. I think that's what I'm going to try next. I'll keep everyone aprised.
David Grason wrote:
. It appears as though I've melted the aluminum and it piled up behind the cutting surfaces rendering them totally useless and ruining a brand new $30 bit.
I'd love to post pictures so you could see what I'm up against and maybe offer suggestions but I can't even get the pics to post right. I think I need a vacation just from building my teardrop.
So if anyone has any idea what the correct and easy/normal way to trim this aluminum is, please help me out. This drove me crazy and I can't do it anymore in the future. There's got to be a better way.
fornesto wrote:I haven't noticed a speed control on my cheapo B&D Router. How else could I slow the speed? Through a voltage dropper? What? Where?
Thanks
