need opinions on this tank as a possible water tank
Postby legend lime » Wed Aug 01, 2007 10:11 pm
I would like to get some opionions on this tank being used as a possible water tank, I picked it up about a year ago to use as a gas tank for a VW Trike I am building but it was to big so I made one. the tank has never been used I had a differant neck welded on but it will be removed and a patch welded over the hold with a fitting for an over flow line and vent. I have the mounting brackets also I will only need to weld on some supports to the frame and run the line back to a pump in the back.
:thinking:
Legned Lime, Acworth, GA
legend lime
Images: 252
Postby Greg M » Wed Aug 01, 2007 10:26 pm
Is it stainless? It looks like it. If so, I say go for it. That's one cool looking tank.
-Greg
Greg M
*Geek Extraordinaire
Images: 85
Postby legend lime » Wed Aug 01, 2007 10:35 pm
nope it's aluminun;
legend lime
Images: 252
Postby Airspeed » Thu Aug 02, 2007 12:32 am
That looks awesome! will you be drinking the water? the reason I ask is will the water get hot sitting in the sun on the tongue? If that doesn't matter I would definitely use it ! How many gallons does it hold?
I think it looks perfect! Aaron
Airspeed
Images: 16
Postby BrianB » Thu Aug 02, 2007 3:54 am
That's the same thing I thought -- looks awesome, but after a day on the road you're not going to want to drink the steam that's left.
Can you mount it inside you galley? It's too pretty to hide, but I don't think you'd ever been happy with it cooking in the sun.
BrianB
Postby mikeschn » Thu Aug 02, 2007 3:58 am
I wouldn't use aluminum for a water tank. Altheimers and all that stuff. But if you could coat the inside of it with something.... hmmmm...
Anyways, it looks cool. You'll find a way to use it.
Postby Alphacarina » Thu Aug 02, 2007 9:06 am
Lots of boats have aluminum tankage with no ill effects
While there are a dozen useful things one could mount on the tongue, I think the trailers look best with nothing there. Since I can't have nothing (my genset just about has to go there) I'm a little bummed, but if I didn't need the genset, no way would I clutter up the tongue with a water tank which is so easy to conceal elsewhere on the trailer. Using some 3 or 4 inch PVC for a tank and mounting it out of the way would be much preferable to me
Don
Alphacarina
Postby jp03 » Thu Aug 02, 2007 9:16 am
Can bet all those water tanks are inside coated. If not, they would all look black for oxydation ! If you did coat the inside, would purge it for days with freash air pumped into it first! Like a cheap aquaruim pump. A portable cheap plastic tank is much easier to remove and fill ? It is a real nice looking tank though!
jp03
Postby Miriam C. » Thu Aug 02, 2007 9:28 am
;) I'd cut it in half and make a tongue box of it. :D
Postby Boodro » Thu Aug 02, 2007 9:17 pm
I would not use aluminum for drinking water either. If ya really wanna use that tank , maybe cut an end cap off & insert a PVC just a little smaller pipe into it & put the cap back on & have a tank ina tank. Put a neck on it & your done. A gallon of water is about 7 pounds so ya probably would fill up at the campground??? 8) 8) 8) Good luck! :thumbsup:
We are all travelers in this world , from the sweet grass to the packin house , birth till death , we travel between the eternities . ( Robert Duvall as Prentiss Ritter)
Boodro
Images: 101
Postby bobhenry » Fri Aug 03, 2007 9:20 am
4" PVC holds about 1 gallon per foot. I intend to belly mount 2 7' runs of 4" and use a small air compressor to pressurize it to about 5 - 7 psi when needed.
Postby Alphacarina » Fri Aug 03, 2007 11:13 am
bobhenry wrote:4" PVC holds about 1 gallon per foot
I think 18 inches of 4 inch pipe is still a little less than a gallon . . . . but I intend to do the same thing you are, though I'll use a pump instead of an air compressor
Don
Alphacarina
Postby bobhenry » Mon Aug 06, 2007 7:12 am
Don
dang it I will need more pipe. Your right at .6527987 per foot 18" holds .979198 gal
The 12 volt pump was $50.00 + the little air compresser is $10.00
