So do you think it was simply that the outside humidity was so high the AC's couldn't pull enough moisture out or is there an econimical solution.
I'm running a 5000btu window unit.
Photo from during construction.
Thanks,
Darren
asianflava wrote:We've experienced this when we camped in muggy muggy Florida and muggy muggy Houston. Some people say that it is because the unit has too much capacity for the space involved. I figure that if it gets cold and stays cold, most of the moisture will condense out.
