David Grason wrote:
For example, I saw on your build where you made the opening for your roof hatch right at 14". Mine is also 14" dead on because that's what the Kuffel plans call for. If I can't find a roof vent to fit right in, I know it's going to be a little extra work to make one fit, but darn, I thought that was the reason we spent the money to get plans from Kuffel.
bdosborn wrote:The galley is killing me!!... I thought I would have the whole trailer done by now. Here's some pictures of my progress.
David Grason wrote:For example, I saw on your build where you made the opening for your roof hatch right at 14". Mine is also 14" dead on because that's what the Kuffel plans call for. If I can't find a roof vent to fit right in, I know it's going to be a little extra work to make one fit, but darn, I thought that was the reason we spent the money to get plans from Kuffel.
asianflava wrote:I was weary of making a hole and the vent not fitting also. I bought my vent fan first, then did the blocking for it. It ended up being exactly 14X14! I can't speak for others since I only have experience with one, but the fan garnish on the Fantastic Fan is smaller than 14X14.
Denzagrad wrote:I like your idea where you located the fuse panel. Uses up what would otherwise be essentialy wasted space and frees up cabint space.
