Pleasant Valley; Yoder Toter wiring ?
Anything electric, AC or DC
Postby gassman » Sun Jul 22, 2007 6:29 pm
Does any one have a wiring diagram for the Pleasant Valley/ Yoder Toter ? After seeing a pic on e-bay I figured this was about as bare bones as it gets for wiring your trailer. I'm just a little puzzled as to where all the wires go...can anyone help??
Here's the photo
Thanks
Rick
gassman
Images: 27
Postby DaytonaGTS » Sun Aug 05, 2007 12:49 am
I'll be able to tell you probably in a week or so, I'll be tearing into mine to wire in a new 7 prong pig tale as soon as it comes in ;)
Ron, Miriam & Ronnie
DaytonaGTS
Postby gassman » Sun Aug 05, 2007 8:24 pm
Ron;
That would be fabulous....Thank You !!!
Rick
gassman
Images: 27
Postby ob1canola » Wed Aug 08, 2007 5:03 am
Whats On the piece of paper tucked behind the trickle charger?
ob1canola
Postby toypusher » Wed Aug 08, 2007 5:44 am
Isn't there a fuse or breaker box somewhere? The main breaker/fuse is in that picture beside the charger, but there must be individual circuit fuses/breakers somewhere.
toypusher
Images: 324
Postby gassman » Wed Aug 08, 2007 8:34 am
OB1;
The piece of paper is the users manual for the battery charger.
Kerry:
That does seem to be the only breaker we could find; there is a cooling fan located in the bulkhead wall; it is possible that is what it is for. Other than that we're puzzled....no other fuses available.
gassman
Images: 27
Postby DaytonaGTS » Wed Aug 08, 2007 5:21 pm
gassman wrote:OB1;
Kerry:
There is a black box in the under bed storage area, I have yet to see what is in there as of yet, but I was expecting a little fuse block somewhere with as much wiring as is in these TD's....
DaytonaGTS
Postby the3beers » Wed Aug 08, 2007 6:50 pm
no black box in mine but my set up looks a little bit different.
the3beers
Images: 20
Postby DaytonaGTS » Wed Aug 08, 2007 10:03 pm
the3beers wrote:no black box in mine but my set up looks a little bit different.
Here is my battery and charger setup, I also just have the 15A fuse.....
Here is the Black box in the under the bed storage area..... it turns out to be a distribution box, what I figured it was........
I'm going to attempt to do a wiring schematic when I do my storage mod. I'm going to first make it a lot easier to access underneath and raise it up an inch to accommodate some storage boxes, and actually make the area usable......
DaytonaGTS
Return to Electrical Secrets
