power 12v lights with just a battery charger?
Anything electric, AC or DC
Postby packerz4 » Fri Aug 10, 2007 7:36 am
Here's the thing. I'm probably never going to hook up a battery. However, the lights are 12v per the way the guy I bought my TTT from built it. I think I suffered a reversed polarity power surge at a campground a few weeks ago. Now the converter I have has something wrong with it.
I'd like to simplify the setup. Do you know of an easy cheap way that would allow me to convert shore 110 power to 12v in order to make the lights work?
I'm wondering if I had a cheap/reasonable battery charger (from any box store) could I power some sort of terminal to light the 12v lights from that when the charger is plugged in? (battery charger $20 -$30, converters i've seen have all been $100+)
So i'd have this:
GFCI and BREAKER protected power cord into TTT, battery charger would plug into this, and then I would hook the battery charger to ___________?
to power the 12v lights. :thinking:
thanks,
tk
~ Go Packers! ~
www.2bagalot.com
packerz4
Images: 53
Postby bobhenry » Fri Aug 10, 2007 7:53 am
Got room for a battery ? If you hook directly to the charger ( which you can ) you may encounter a 60 cycle hum with certain 12 v lighting or appliaces. If you hook the charger to a battery then run to your 12v system this will dampen this. Got a car with a 3 year old battery buy the car a new one and use the old one ! (too big)
how about a motorcycle or small lawn tractor battery. Don't forget to fuse from the battery to the load on the positive side. One of those in line fuse holders should be enough depending on your total load.
Postby packerz4 » Fri Aug 10, 2007 8:43 am
that makes sense, then i'd have the lights when i need them off the battery. thanks!
i also found this on radio shack's website:
radioshack clicky
might be a safe route, for regulated power...
tk
~ Go Packers! ~
www.2bagalot.com
packerz4
Images: 53
Postby Darren » Fri Aug 10, 2007 9:29 am
I use an old computer power supply to run some 12v lights in my computer room. :thumbsup:
Darren
the camper formerly known as Victor Star
Images: 161
Postby Arne » Fri Aug 10, 2007 9:44 am
A small battery sounds like a good idea.. you don't think you will ever use it, but even if you just stop at a rest area at night and want something in the trailer, it makes it easier.....
Talking about batteries, I put in a high priced car battery from Sam's, the kind that looks like 6 cylinders (similar to Optima)... I'm not sure I would spend the 125 bucks again.... maybe, but not sure.. with a generator, I could always recharge the battery pretty much any place I camp.... and those darn batteries are heavy suckers..... like around 60 pounds, if I remember correctly.
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby caseydog » Fri Aug 10, 2007 10:04 am
What about a Malibu Lights garden light power supply?
My build journal is HERE
caseydog
Images: 515
Postby Dale M. » Fri Aug 10, 2007 10:23 am
Only problem with Radio Shack unit, is tech specs. does not give how many amps the output is... Typically these units put out 3-5 amps. Unit may not have capacity to run some of the items you want to power with it...
Dale
Dale M.
Images: 18
Postby Dale M. » Fri Aug 10, 2007 10:30 am
caseydog wrote:What about a Malibu Lights garden light power supply?
Think Malibu lights are 6.5 volts... At least one set I saw advertised were specifying that voltage...
Dale
Dale M.
Images: 18
Postby Endo » Fri Aug 10, 2007 11:47 am
Brad (aka Endo)
ImageImage Image
In God We Trust
Endo
Images: 138
Postby Alphacarina » Fri Aug 10, 2007 12:19 pm
A battery charger isn't a suitable power supply unless you have it connected to a battery - Unloaded, it may have an output as high as 18 or 20 volts and your 12 volt lighting wouldn't last long operating on those voltages
A small regulated power supply is a better choice . . . . but then I really think you would be happier using a small battery in the long run - You can't always plug it in ;)
Don
Alphacarina
Postby packerz4 » Fri Aug 10, 2007 12:35 pm
Alphacarina wrote:. . . . but then I really think you would be happier using a small battery in the long run - You can't always plug it in ;)
Don
ok, i'm being sold on the battery thing. i like what Arne said too, about the times when you'd like the light to work, like a rest area etc. Soooooooooooooooooooooooo
how do I hook all the 12v light wires onto a battery?
i will have a battery charger hooked to the shore power, and the charger hooked to a small battery, then how do i connect the lights to the battery.... one huge pigtail and a connector?
thanks in advance. i think i'm going to be way happier with this set up than my current one.
tk
~ Go Packers! ~
www.2bagalot.com
packerz4
Images: 53
Postby bobhenry » Fri Aug 10, 2007 1:00 pm
Go to Joanne's dessert dawg web site and click on electrical 1 in her build journal. Real nice visual schematics that are easy to understand.
P.S. Thanks Joanne I used them as a resource too
Bob
Postby packerz4 » Fri Aug 10, 2007 1:36 pm
bobhenry wrote:Go to Joanne's dessert dawg web site and click on electrical 1 in her build journal. Real nice visual schematics that are easy to understand.
Bob
thanks bob!! (and joanne)
though i'd been to her site a few times, i never took in the detail of the wiring, this is just what i needed.
thanks again!
tk
:applause:
~ Go Packers! ~
www.2bagalot.com
packerz4
Images: 53
Postby Alphacarina » Fri Aug 10, 2007 9:13 pm
That's not Bret Farve in your picture . . . . wrong number ;)
Bret is a local boy, quite revered in these parts - We can't wait to get him back when you GreenBayers are done with him ;)
Don
Alphacarina
Postby BrwBier » Fri Aug 10, 2007 9:32 pm
The power supply from under cabinet puck lights are good for up to three 10watt halogen lights.
brwbier
BrwBier
Images: 100
Return to Electrical Secrets
