beevel wrote:Did you fit any weather stripping inbetween your jams, or is it just wood to wood sealing?
beevel wrote:Your door is the same thickness as your trailer walls correct? If so did you have to offset your jams to make room for the weatherstripping?
steve wolverton wrote:If we're gone, (biking) then I'll leave it open so you can rummage around inside.
nikwax wrote:Question on framing the sides: looks like you used 1x2, correct? Did you use scrap ply for the curved section framing, or did you cut down 1 by?
