Top Fuel Dragster
Top Fuel Dragster
Postby halfdome, Danny » Thu Aug 09, 2007 10:49 pm
I'm no gear-head but found this very interesting :) Danny
One Top Fuel dragster 500 cubic inch Hemi engine makes more horsepower than the
first 6 rows at the Daytona 500.
Under full throttle, a dragster engine consumes 1 gallon of nitromethane per
second; a fully loaded 747 consumes jet fuel at the same rate with 25% less energy being produced.
A stock Dodge Hemi V8 engine cannot produce enough power to drive the dragster
supercharger.
With 3000 CFM of air being rammed in by the supercharger on overdrive, the fuel
mixture is compressed into a near- solid form before ignition.
Cylinders run on the verge of hydraulic lock at full throttle.
At the stoichiometric 1.7:1 air/ fuel mixture for nitromethane the flame front
temperature measures 7050 degrees F.
Nitromethane burns yellow. The spectacular white flame seen above the stacks at
night is raw burning hydrogen, dissociated from atmospheric water vapor by the
searing exhaust gases.
Dual magnetos supply 44 amps to each spark plug. This is the output of an arc
welder in each cylinder.
Spark plug electrodes are totally consumed during a pass. After ½ way, the
engine is dieseling from compression plus the glow of exhaust valves at
1400 degrees F. The engine can only be shut down by cutting the fuel flow.
If spark momentarily fails early in the run, unburned nitro builds up in the
affected cylinders and then explodes with sufficient force to blow cylinder
heads off the block in pieces or split the block in half.
In order to exceed 300 mph in 4.5 seconds dragsters must accelerate at an
average of over 4G's. In order to reach 200 mph well before half-track,
the launch acceleration approaches 8Gs.
Dragsters reach over 300 miles per hour before you have completed
reading this sentence.
Top Fuel Engines turn approximately 540 revolutions from light to light!
Including the burnout the engine must only survive 900 revolutions under load.
The redline is actually quite high at 9500rpm.
It takes 1500+hp just to turn a top fuel blower.
The pressure coming out of the headers can provide 1000lbs of down force. When a cylinder goes out, it can
actually steer the car due to loss of down force on one side.
There is so much torsional twist in the crankshaft (up to 20 degrees at the big
end of the track) that sometimes cam lobes are ground offset from front to rear
to try and re-phase the valve timing closer to synchronization with the pistons.
The car will be going over 60mph before the rear wheels cross the start line,
300 inches.
The Bottom Line; Assuming all the equipment is paid off, the crew worked for
free, and for once NOTHING BLOWS UP, each run costs an estimated US $1,000.00
per second. The current Top Fuel dragster elapsed time record is 4.441 seconds
for the quarter mile (10/05/03, Tony Schumacher). The top speed record is 333.00
mph (533 km/h) as measured over the last 66' of the run (09/28/03 Doug Kalitta).
Putting all of this into perspective:
You are driving the average $140,000 Lingenfelter "twin-turbo" powered Corvette
Z06 (or blown Viper). Over a mile up the road, a Top Fuel dragster is staged and ready to launch
down a quarter mile strip as you pass.
You have the advantage of a flying start. You run the 'Vette hard up through the
gears and blast across the starting line and past the dragster at an honest
200 mph. The 'tree' goes green for both of you at that moment.
The dragster launches and starts after you. You keep your foot down hard, but
you hear an incredibly brutal whine that sears your eardrums and within 3
seconds the dragster catches and passes you. He beats you to the finish line, a
quarter mile away from where you just passed him.
Think about it, from a standing start, the dragster had spotted you 200 mph and
not only caught, but nearly blasted you off the road when he passed you within a
mere 1320 foot long race course.
halfdome, Danny
*Happy Camper
Images: 252
Postby steve wolverton » Thu Aug 09, 2007 10:57 pm
I don't know much about them either, but I'll stop and watch them while flipping through the channels.
FUN FACTS
Did you know …
… that the nitromethane-powered engines of NHRA Top Fuel dragsters and Funny Cars produce approximately 7,000 horsepower, about 37 times that of the average street car?
�veni, vidi, vici.�
steve wolverton
Images: 11
Postby DaytonaGTS » Thu Aug 09, 2007 11:40 pm
Pretty sweet huh?
When I went to the NHRA Museum at Pamona, they had alot of those same facts, and a working dispay to show you just how much fuel is being used.... just watching the fuel come out of the Injector (if you want to call it that) was amazing....
Ron, Miriam & Ronnie
DaytonaGTS
Postby doug hodder » Thu Aug 09, 2007 11:59 pm
thanks for that post Danny...now you know why I don't fire up the Rambler as much as I should...it can be a "handful"when the rear "meat" gets hooked up!!! John Force is coming over this weekend to help me "de-tune" it for street use!!! :lol: :lol: :lol:
Postby Chip » Fri Aug 10, 2007 4:32 am
Talk about a speed rush,,,, wouldnt I like to have a ride in one,, somebody else driving though,,, handling that much power sure aint fer this rookie ,, I had the good fortune to get to ride and drive a Hemi powered trike, 1958, 392 hemi, tuned up to a mild 515 HP, 1700 lbs fully loaded with rider, the owner Roy Young, jokingly says it will do a minute in 20 seconds,, dang if I dont believe him,,,
chipper
54"x9'4" tear
4'x8' tear
Chip
Images: 49
Postby gassman » Fri Aug 10, 2007 7:24 am
Yea!!!
All that and the engine only gets to turn aruond (RPM.revolution per minute) about 600 times a pass!! My Jeep engine rotates more times than that just getting it out of the garage!!!
Rick
gassman
Images: 27
Postby Arne » Fri Aug 10, 2007 8:47 am
Yes, 5 seconds worth of 7,500 rpm isn't that much....
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby halfdome, Danny » Fri Aug 10, 2007 10:11 am
doug hodder wrote:thanks for that post Danny...now you know why I don't fire up the Rambler as much as I should...it can be a "handful"when the rear "meat" gets hooked up!!! John Force is coming over this weekend to help me "de-tune" it for street use!!! :lol: :lol: :lol:
Doug, thats funny :lol: My folks bought a Rambler station wagon in 1959 because it was economical on gas. :) Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby ALAN GEDDES » Fri Aug 10, 2007 6:29 pm
I remember that trike Chip. It was scary but very cool.
Alan
ALAN GEDDES
Images: 34
Postby AlaskaJack » Fri Aug 10, 2007 9:03 pm
Waaaaaay back when I was in the submarine service..... 1962 to be exact, I took my '57 Chevy to the drags.....(Half Moon Bay, SF. CA) and entered! 8)
Well.... to make a long story very short, I was brutally dusted at the first get go! (I don't think the other '57 I was up against was stock!!! .... but it was fun!) That was the start and finish of my "racing" career.
AlaskaJack
Postby AlaskaJack » Fri Aug 10, 2007 9:11 pm
Chip wrote:Talk about a speed rush,,,, wouldnt I like to have a ride in one,, somebody else driving though,,, handling that much power sure aint fer this rookie ,, I had the good fortune to get to ride and drive a Hemi powered trike, 1958, 392 hemi, tuned up to a mild 515 HP, 1700 lbs fully loaded with rider, the owner Roy Young, jokingly says it will do a minute in 20 seconds,, dang if I dont believe him,,,
chipper
The folks just around the corner from me have a couple of those "Boss Hoggs" (sorry if I didn't call them the right name!) ..... with the Chevy V8's in them. His is a two wheeler..... hers is a trike. No clue if they are the 350's or the 427's ...... but they sure look and sound cool! (I'm so thankful for having sold my HD "Wideglide" a couple of years ago!! .... yeah, lots of fun.... but I'm "too slow" to be riding any more!) :D
AlaskaJack
Postby sledge » Sat Aug 11, 2007 9:17 pm
I know what you mean Chip, I have a NICE 1975 GT750 Suzuki, and 2 Really BAD GT750 Engs. ,,,, BUT, I have a 1981 GS1100 Suzuki (Wrecked) , just like the one Vance & Hines had back then ,that was the fastest on the planet at one time. and I been planning on putting that GS1100 eng, on the GT750 frame ....... but, that might not be a good idea. I guess I need more life ins, FIRST ! ! :oops:
sledge
Images: 26
