Small Technical Problem - Advice Needed.
Postby Classic Finn » Sun Aug 12, 2007 3:46 pm
Ok a few minutes ago :duh :shocked:
I noticed a lil technical error on the body side (not body side hinge) ... but the rib that it will be sitting on..
I can move it a small tad with my hand.. Im just not sure that it is sturdy enough there...to hold the hinge in place. Here is what I mean..
How can it be fixed so it will ... The top and lower end of the hatch is oak...so should I step back and laminate 2 oak boards together and replace that body section since its not oak..
and what is a method of strengthening it? Ideas or Photos anyone?
Classic Finn
Classic Finn
Midnight Sun Voyager
Images: 146
Postby Micro469 » Sun Aug 12, 2007 4:33 pm
Hey Finn... What are you covering your roof with? If you got it covered with 1/4 ply it should not move....
John
Micro469
Images: 382
Postby Classic Finn » Sun Aug 12, 2007 4:43 pm
Micro469 wrote:Hey Finn... What are you covering your roof with? If you got it covered with 1/4 ply it should not move....
John its 3 millimeter Ply plus 1.5 millimeter fiberglass (Sorry dont know the Product Name). 4.5 millimeter in total..or 4.5 mm = 0.177165 in
Classic Finn ;)
Classic Finn
Images: 146
Postby PaulC » Sun Aug 12, 2007 4:51 pm
Heikki, if you are using the poly hinge, it will firm that support up when you screw it along the length. I'm assuming that you are referring to a certain amount of flex in that spar.
Cheers
Paul :thumbsup:
PaulC
3rd Teardrop Club
Images: 36
Postby Mike C. » Sun Aug 12, 2007 5:20 pm
Heikki you need to remember that your hatch isn't going to put pressure in one spot like you hand. The inside cabinets will firm up the adjoining walls too. Your hinge will give it some strength
My spar spans 6' so I put a 1x3" across to frame in the shelf and give it support
Uncle M ( Mike )
Mike C.
our Uncle M
Postby Dean in Eureka, CA » Sun Aug 12, 2007 5:25 pm
Heikki,
To assure I had no issues with flex on my hatch hinge beam, I tripled up some 3/4" oak... 2 1/4" thick overall, width varies because it's profile is a trapezoid. The beam also butts up against and is attached to the bulkhead. I can stand on it and it doesn't flex...
I will most likey do another "beefy" roof spar somewhere towards the front of the cabin area, should I ever decide to do a roof rack, I'll have solid mounting support areas...
Dean in Eureka, CA
The Fogcrawler
Images: 69
Postby Classic Finn » Sun Aug 12, 2007 6:05 pm
PaulC wrote:Heikki, if you are using the poly hinge, it will firm that support up when you screw it along the length. I'm assuming that you are referring to a certain amount of flex in that spar.
Cheers
Paul :thumbsup:
Paul yes indeed thats what I mean exactly. :thumbsup:
Classic Finn ;)
Classic Finn
Images: 146
Postby Classic Finn » Sun Aug 12, 2007 6:08 pm
Mike C. wrote:Heikki you need to remember that your hatch isn't going to put pressure in one spot like you hand. The inside cabinets will firm up the adjoining walls too. Your hinge will give it some strength
Ok so my thoughts and worries are then over nothing I guess. And yes the back cabinets are still to be built in that area.. ok thank you, I feel better about it now.. Im glad I asked though because it would of been on my mind constantly...
Thank You
Classic Finn ;)
Classic Finn
Images: 146
Postby Classic Finn » Sun Aug 12, 2007 6:11 pm
Dean in Eureka, CA wrote:Heikki,
Okidoki Deanster.. To me it just seemed a lil awkward there. And also the interior cabinets arent in so they will help ..
Whew... ;)
Classic Finn :thumbsup:
Classic Finn
Images: 146
