Making Progress on Galley
Postby TonyCooper » Thu Mar 10, 2005 1:21 am
Well....
Slowly but surely my galley is starting to come into focus. Not nearly as fancy as many I've seen but hopefully functional enough.
I now know I am not cabinet maker material! :roll: I think I better keep my day job. I'd starve making cabinets....
For pictures click on my build link below.
My Tear Build Site
"No comment"
TonyCooper
Official Pot Stirrer
Images: 35
Postby asianflava » Thu Mar 10, 2005 3:51 am
Where did you get the water tank made?
asianflava
Postby TonyCooper » Thu Mar 10, 2005 8:56 am
I purchased the tank here:
http://www.watertanks.com/rectangulartanks/
I purchased this one:
http://www.watertanks.com/drawing/2139/ ... /0260-132/
But there are many to choose from:
http://www.watertanks.com/products/0260-132.asp
The are pricey, but very high quality.
My Tear Build Site
"No comment"
TonyCooper
Images: 35
Postby BrianB » Thu Mar 10, 2005 9:32 am
Your cabinets look very cleanly done. Nice work.
I'd have a hard time paying $100 for a water tank, but the space savings make it seem worth it. I wonder how much used RV parts dealers would sell similar tanks for.
BrianB
Postby asianflava » Thu Mar 10, 2005 3:16 pm
Thanks for the info, I'm still on the fence as to wether I'm going to install a sink. If I do, I want to put the tank in between the frame rails. Either a tank like yours, or the 6in PVC pipe that I originally was planning.
asianflava
Postby TonyCooper » Thu Mar 10, 2005 5:07 pm
asianflava wrote:Thanks for the info, I'm still on the fence as to wether I'm going to install a sink. If I do, I want to put the tank in between the frame rails. Either a tank like yours, or the 6in PVC pipe that I originally was planning.
The reason I went with this tank was the fit was exact for between the rails placement and it did not drop down much below the frame. It was expensive though.
My Tear Build Site
"No comment"
TonyCooper
Images: 35
Postby emiller » Thu Mar 10, 2005 6:01 pm
8) My tank looks almost the same but it is tapered to clear any ground problems, lower in the front higher in the back and holds 15 gal. of water.
gives me more space. I'll post a picture this weekend.
emiller
Images: 157
Re: Making Progress on Galley
Postby bdosborn » Thu Mar 10, 2005 8:37 pm
TonyCooper wrote:Well....
Me likey! You can tell you spent a lot of time laying everything out so it fits just right.
Images: 806
Postby BufordT » Fri Mar 11, 2005 3:53 am
Nothing wrong with those cabinets Tony. Good job.
Like the way the web site is done also with the notes.
Bufordt :twisted:
"RUSH" The Man, The Legend, The Way Of Life.
BufordT
2nd Teardrop Club
Images: 23
Postby San Diegan » Fri Mar 11, 2005 12:55 pm
Tony, your cabinets are very handsome.
I have also visited the watertanks site and eyed the 5" high models. That seems to be about as thin as they get.
emiller, I like the idea of a tapered tank. Did you fabricate it yourself or purchase it?
Thanks,
San Diegan
Postby toypusher » Fri Mar 11, 2005 1:02 pm
Try this site for tanks, they have 4" thin tanks.
[url]http://www.plastic-mart.com/class.php?item=39
[/url]
Check the rectangular and marine tanks.
toypusher
Images: 324
Postby San Diegan » Fri Mar 11, 2005 1:34 pm
Wow. Thanks toypusher. This is another resource for my Teardrop Parts browser bookmarks.
San Diegan
Postby TonyCooper » Sat Mar 12, 2005 1:00 am
Thanks Folks for all the kind words of encouragement.
It is starting to come together and I am having fun.
Whenever you build anything you know all the warts that most never see. The builder tends to be his own worst critic.
Just wait till I start the doors! I have a brand new set of router bits designed for those fancy joints my kitchen cabinet doors have. I'll practice on a few pieces of pine before trying on the oak.
Ever Onward!
My Tear Build Site
"No comment"
TonyCooper
Images: 35
Postby TonyCooper » Sat Mar 12, 2005 1:10 am
San Diegan wrote:Tony, your cabinets are very handsome.
Thanks,
Mine is 4 3/4" tall. The area above the tank consists of two 3/4" plywood floor sections and one 3/4" thick sheet of hard insulation, then an aluminum sheet for a vapor barrier. My tank hangs only 2" below the trailer frame. Well above the axle.
I could have tucked it up even more by not installing the insulation and the additional 3/4" plywood section. The tank would then only hang 1/2" below the trailer frame.
My Tear Build Site
"No comment"
TonyCooper
Images: 35
Postby GeorgeT » Sat Mar 12, 2005 11:55 pm
Hey Tony,
Great job. Was wondering did you bend the aluminum straps that hold your tank in place. Was thinking on the same lines to carry my spare underneath the trailer so's I could slide it out when needed instead of bolting and unbolting it to the underside of the floor. Was concerned that bending the aluminum strap might compromise its strength or crack it where it was bent. Did you heat the aluminum. Have never bent any aluminum strapping but thought it might work. I figure the tire would weigh less than the tank and water. Thanks :thinking:
Lookin' up in da skize with ize on da prize
http://home.earthlink.net/~g.teague/
GeorgeT
