http://www.kregtool.com/
demtears wrote:For those starting there teardrop project, and plan on building with a Pocket Hole Jig I just picked up the kreg k3 master system it has a limited time offer $20 dollar mail in rebate good until september 30th every little bit helps.![]()
cuyeda wrote:Which technique is more preferred, Kreg pocket hole joiner, or biscuit joiner?
I have a HF biscuit joiner (was gettin' ready for a TD build), but only used it one time. Many people praise the Kreg system, and seems like it makes a strong assembly.
Would the biscuit joiner method provide strength also? After drilling the holes, do you fill it in to make it look purdy, or do you just leave it as is?
rbeemer wrote:
Also be sure to use glue, there is squeeze out but there is still glue left in the joint.
Steve F wrote:My wife ordered me a pocket hole jig for Fathers day (September 7th here in Australia) I cant think of an easier way to build the frame for the walls than this so look forward to getting it so I can move on to the next step of the build
Cheers
