Here is a cut away of my door trim and gasket. I do not have the gasket material here yet but it is on order from Grant at Lil Bear.
I would like to hang my doors soon, but I need the dimension on the thickness of the gasket material with the door closed. Anyone out there using Grants Door seal gasket material?
I still have to cut the rabbit joint (for lack of a better word or description) on the trim and that depends on the thickness of the gasket when compressed.... or should I just wait till it comes in??
In short, what would the dimension be for the ? in the above sketch?
Thanks,
Mk
