Door Gasket/Seal question--- Pics added 8-30
Postby Mary K » Thu Aug 23, 2007 3:44 pm
Here is a cut away of my door trim and gasket. I do not have the gasket material here yet but it is on order from Grant at Lil Bear.
I would like to hang my doors soon, but I need the dimension on the thickness of the gasket material with the door closed. Anyone out there using Grants Door seal gasket material?
I still have to cut the rabbit joint (for lack of a better word or description) on the trim and that depends on the thickness of the gasket when compressed.... or should I just wait till it comes in??
In short, what would the dimension be for the ? in the above sketch?
Thanks,
Mk
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby madjack » Thu Aug 23, 2007 4:55 pm
MK, I don't know the thickness of Grants weatherstripping BUT you will want to achieve a 50% compression of the seal...
madjack 8)
Postby Mary K » Thu Aug 23, 2007 6:26 pm
Thanks MadJack! Knew you would be there for me. :thumbsup:
Mk
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby Mary K » Thu Aug 23, 2007 6:38 pm
Freebird, Thanks! :thumbsup: I had just gotten through figuring out the gap should be 3/16 when I refreshed and found your post.
I am so glad you posted with the info and the thumbs up for the seals Grants offers. I could not find any of that style localy.
Mk
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby Micro469 » Thu Aug 23, 2007 8:47 pm
Mary, Mary, Mary......... Can't you do anything by yourself????? :lol:
John
Micro469
Images: 382
Postby Ken A Hood » Thu Aug 23, 2007 8:50 pm
From Grant's website:
Disclaimer: I in no way resemble the avatar shown. Furthermore, I in no way have any affiliation to the Trailer Park Boys and more specifically Bubbles!
Ken A Hood
Images: 42
Postby doug hodder » Thu Aug 23, 2007 8:58 pm
Mary another approach to giving yourself the relief for the gasket material is to shim out the door with a strip of aluminum on the hinge. Ideally, the offset hinges work really well and I've used them in the past for that offset, I get the 1/8" offsets. With your door framing, offsetting the door isn't really going to show up as the door frame breaks the plane of the flat surface anyway and one might be hard pressed to see that the door is offset. Just what I've experienced. Doug
Postby BrwBier » Thu Aug 23, 2007 9:23 pm
I would mount the doors first and then measure to see what amount of room you need to fit the weather strip. If your doors don't fit as you envisioned then you still have the chance to adjust how the trim fits the weather strip.
Brwbier
BrwBier
Images: 100
Postby Mary K » Fri Aug 24, 2007 10:11 am
Micro469 wrote:Mary, Mary, Mary......... Can't you do anything by yourself????? :lol:
NO!!!! :crying1: :crying1:
My Daddy is in Stinson Beach, CA on vacation and I can not ask him... :cry: :cry:
:fb You are my Spanky List John!!! Picking on me...bad boy...
Mk :R :D ;)
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby Mary K » Fri Aug 24, 2007 10:20 am
Thanks for your help Guys!!
I am using the bullet hinges, kinda like Victor Star's doors. The trim will go all around the door and the hinges will be mounted to the top of it and a offset.
Mk
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby MrBuzz » Thu Aug 30, 2007 1:00 pm
MaryK;
I can't be much help at all...The doors on mine are similar and I didn't leave enough gap for the weatherstrip and had to re-do my hinges, Ugh.
Just wanted to say....GLAD TO SEE YOUR TEARDROP DANCE IMAGE IS BACK!!!
MrBuzz
Generic Benroy - built 2007, 4X8, 1175 HF trailer, Structoglass roof and headliner, 12v and 110v electrics with Schumacher charger.
MrBuzz
Images: 77
Postby Mary K » Thu Aug 30, 2007 1:15 pm
Thank ya Mr Buzz.
Here are some updated Photos of the first door installed.
I still need to route out where the gasket is installed... :thinking: Thinking I can get away with just routing out the trim edge that the hinge is installed on. Thats where it will be pinched the most.
I will post pics when the gasket is installed.
Mk
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby James & Avisia Flohr » Thu Aug 30, 2007 1:21 pm
I can only assume that if your Teardrop is as outstanding as your graphics :shock: , it will be a sight to behold.. Keep up the GOOD work. I'm impressed! Jim
'Live, Love, Laugh and Be Happy'
Postby Mary K » Thu Aug 30, 2007 1:33 pm
James & Avisia Flohr wrote:I can only assume that if your Teardrop is as outstanding as your graphics :shock: , it will be a sight to behold.. Keep up the GOOD work. I'm impressed! Jim
Thanks Jim! :D
I have used Autocad for a living for 15 years now... but I only have 1 year with wood.... Go figure... :?
Mk
Mary K
Mary K
6000 Club
6000 Club
Images: 44
