Shower pan?
Shower pan?
Postby nikwax » Sun Aug 26, 2007 6:24 pm
In another thread we started talking about low cost shower pan options. I haven't seen anything like what was being discussed, I dropped by Home Depot today and they only stock $$$ shower pans. I can make one out of fiberglass/epoxy but wouldn't mind finding something pre-made or modifiable if it were economical.
Anyone??
nikwax
Images: 30
Postby Weerider » Sun Aug 26, 2007 7:45 pm
That is a shower pan "to be", it looks like a laundry sink that is about to be cut down to make a shower pan.
Howard
The ones who say it cannot be done should stay out of the way of the ones who are doing it!
Weerider
Images: 99
Postby GPW » Mon Aug 27, 2007 6:42 am
What about a shallow plywood box , with fiberglass on the inside... sealed very well .... we used a similar box for a printers water box for 20 years ... oughta' be thrifty enough ... just something else to build and pretty easy to do a custom size... :thinking:
Postby goldcoop » Mon Aug 27, 2007 8:43 am
Nikwax-
Don't know what size your looking for BUT check these out:
http://www.rvsurplussalvage.com/catalog ... ory_id=171
Cheers,
Coop
goldcoop
Images: 32
Shower pans
Postby Rebel » Mon Aug 27, 2007 11:03 am
Here's a link to shower pans http://www.pplmotorhomes.com/parts/rv-pumps-water/rv-shower-pans.htm. But I like the idea of making your own from plywood and fiberglass - more economical and able to customize it. I am working on a modified puffin on the harbor freight trailer, so I want to build the box to set on the floor when in use. If I build another one later on, I would weld up a trailer and set the steel to accept a dropped floor for the shower box. I could cover the box when not in use, giving more room across the front.
Rebel
Building a Tear for Retirement
Rebel
Postby len19070 » Mon Aug 27, 2007 8:55 pm
I built mine.
I just couldn't find one the right size.
I made it 32X42 by using an excess piece of 32 gage aluminum. I did all the metal bending in a door frame. Cut the drain hole in it where I wanted it.
I figured the actual cost was about $25 plus the drain. (based on using 1/2 sheet of aluminum, a full sheet was $50).
The room is so small I don't really have any good photos of the finished product.
BUT...I was out the other day and I saw one of these.
http://www.smarter.com/---se--qq-washin ... +pans.html
They looked sturdy enough, if installed with proper backing.
I'm sure you could get one locally.
Happy Trails
Len
len19070
Images: 24
