For the sides I am using cheap dollar store pure brissal brushes, I sanded between coats. What am I doing wrong? Not sanding enough? Cheap brushes? So far I am going through 6 sheets of sandpaper for each coat.
I need help to obtain the perfect finish... I don't want to keep applying epoxy if it's not going to get better.
Edit.. One other question.. When I get to the final coat, and want to apply clearcoat... Do I have to sand it AGAIN???
All you Epoxy Guru's.... Any advice??? Doug?????
