CCC Woody - tent trailer
really
Postby Jeeper92 » Sat Aug 25, 2007 8:00 pm
I gotta think a 6cyl can pull more then a 4
Jeeper92
Postby jeepr » Sun Aug 26, 2007 6:56 am
I like it! We had a Coleman camper that was along the same design. It was a little bigger than yours and had a large door on either side that flipped down. It was the best for storing stuff. When set up, the one side was accessible from the outside and the other was accessible from the inside. The bed was at least queen size and the tent area was huge. It had a canvas cover that snapped down over the top when it was closed up.
My grandfather had the Apache that folded out on each side and you went inside through the rear.
Good luck.. :thumbsup:
Mike C.
jeepr
Images: 38
Re: really
Postby jeepr » Sun Aug 26, 2007 7:01 am
Jeeper92 wrote:I gotta think a 6cyl can pull more then a 4
You would think so, but if your still talking Wranglers, they are both rated for 2000 pounds. They are limited by their wheelbase. It really is no fun towing anything heavier with a Wrangler. I have moved my boat around with mine and it's real squirrelly and feels like the "tail is wagging the dog". My boat is right around 2000 pounds.
Mike C.
jeepr
Images: 38
Postby jagular7 » Sun Aug 26, 2007 6:14 pm
I pulled the 2300# Scamp with my Wrangler when it was stock. It basically pulling to a stop on highway hills...no not really but in 2nd gear (manually put in it) @40mph just didn't feel like I could use the 2 together. And since it weighed more than the TJ, I was hesitant to make turns with any kind of speed. (Drove only 2-3 miles to test it out.)
I didn't want to pay for storing the Scamp (@$360/yr), so I sold it. Then went looking for something lighter and smaller and found this forum. That was some time ago.
Mike
Jagular
Lenexa, KS
jagular7
Postby schaney » Sun Aug 26, 2007 6:58 pm
Ok, per Edmunds ...
2001 TJ 2000 lbs capacity for both 4 and 6 cyl, it's a short wheel base thing not power.
2006 TJ 4 cyl 1000 lbs, 6 cyl 2000 lbs and Unlimited 3500 lb
It's a short wheel base thing not power, the Unlimited has a longer wheel base, a tad more weight, but the same 6 cyl and it gets a 1500 lb higher rating.
Scott
Camping the "Compact Way"
schaney
Images: 262
tahnks
Postby Jeeper92 » Mon Aug 27, 2007 8:21 am
thanks
Jeeper92
Postby tj0llll0 » Sat Sep 22, 2007 9:05 am
Ive got to think its a liability issue for JEEP. If I remember correctly, the towing capacity on a, say 73 CJ5, was about 5000#s. I used to flat tow a CJ5 with a CJ5 (It was a little modified, 9" rear and 4:56 gears).
John in Vegas
tj0llll0
Postby schaney » Sat Sep 22, 2007 3:43 pm
Yes, I'm sure liability plays a big part in the sue happy US. In many other countries the same vehicle will carry a higher tow rating.
What I find funny is my Miata is not tow rated in the US, although I can buy a hitch rated for a 400lb trailer. So I wonder what my insurance company will say if I have an accident and I'm towing?
Scott
schaney
Images: 262
Slightly off topic
Postby jay » Sat Sep 22, 2007 6:41 pm
[quote="schaney"]... when sleeping during transit. [/quote]
isn't this illegal & a little dangerous? or have i watched 'The Long Trailer' too many times?
jay
Postby schaney » Sun Sep 23, 2007 10:26 am
Jay, did I miss something :shock: when did sleeping become illegal :cry:
Scott
schaney
Images: 262
Postby bgeddes » Fri Dec 21, 2007 1:33 am
Wranglers have an issue with brakes and a short wheelbase for towing. Better choices for towing would be the Cherokee (84-01, and designated XJ), or a Liberty (still called a Cherokee overseas, designated KJ), if you are not so worried about fuel mileage, the Grand Cherokees (designated as WJ or ZJ) are good options.
The newest Jeeps use different two letter designations, many with a K instead of a J.
For you Jeep owners, Jeepforum is as much about Jeeps as this forumis about Tears.
bgeddes
