sleepercatcher wrote:I've looked at the HF trailers, I'd really like a 5 x 8 or even a 5x10 frame. From your comments I should be looking for something rated at least 1750lbs. I was just thinking that running gear taken from an existing trailer would be as easy to work with and if I can find one in someone's yard that they want moved, it would be cheaper
sleepercatcher wrote:One more thing, has anyone out there built a teardrop using a trailer made from a pickup truck frame cut to make a trailer?
bobhenry wrote:Pro's for pick up frame.....
Without motor and cab the payload should EASILY excede 2000#
