Alphacarina wrote:I'm not so sure our $35 membership is a good idea either - My bill to get out of there yesterday was $550![]()
Alphacarina wrote: The generate no explosive hydrogen gas when they're charging, so they're great for enclosed spaces . . . . especially spaces shared with living beings who would breathe in the gases.
Alphacarina wrote:10 years for an Optima isn't all that unusual - I have a 6 year old one in my Miata, still going strong and I expect it's got several years left
Optimas have some other advantages too - They contain no liquid, so you don't have to keep them topped off. The generate no explosive hydrogen gas when they're charging, so they're great for enclosed spaces . . . . especially spaces shared with living beings who would breathe in the gases. They're spillproof, so you won't have corrosive acid where you don't really want it. Bouncing around in a towed trailer doesn't hurt them or cause them to leak. They don't build up corrosion on the posts like lead acid batteries do. They can be discharged much deeper without shortening the life of the battery than lead acid batteries can. They can be left discharged longer too, without harm. They 'self discharge' about one tenth as fast as ordinary batteries do, which makes them great for trailers which are seldom used
But yes, you CAN use cheaper batteries, though you will probably pay more for your DC power in the long run, because you WILL probably replace an ordinary lead acid battery 3 or 4 times as often as if you had bought an Optima in the first place
Don
asianflava wrote:Alphacarina wrote: The generate no explosive hydrogen gas when they're charging, so they're great for enclosed spaces . . . . especially spaces shared with living beings who would breathe in the gases.
They do generate dangerous gasses when charging, just not nearly as much as lead acid batteries do. They offer a vent kit for installations in totally enclosed areas.
Q wrote:Sorry, I don't buy the hype
Alphacarina wrote:They don't vent anything in 'normal operation' - You CAN overcharge them and force them to vent, but you won't have a good battery for very long.
TD4FREEW/CTD wrote:I have had serious trouble bringing an optima battery back from the dead.
put it on a battery tender/charger and took a week to give me the green light. still have not tested it in a car. the charging system of the car was not getting it going after it was jumped.
then again, this was in a 57 Fury. the charging system could have been toast.
have not really had any problems with the optima in my pickemup truck.
