toyota truck and carolla have seprate yellow blinkers
Anything electric, AC or DC
Postby Ron Dickey » Fri May 25, 2007 10:53 am
I finally figured out hot to post pix so
here is what I got and what I got to work with.
there are plugs where the lights are that plug into the lights is there an extention wire for that??
I did not do that shot I should have :oops:
Ron
173882......173887
Ron Dickey
Images: 787
Postby Ron Dickey » Sun Sep 02, 2007 5:58 pm
I am happy to report that I got the Draw tite 18379 it works for 1989-95 toyota pickups and 1995-2004 Toyota Tacoma pickups :D :applause: :applause:
it came with a simple plug I removed the tailights with 4 screws each unpluged the intire light unit for each side.
It came with plugs that went between the truck wire plug and the light unit plug.
puged them in checked the lights still worked. used a trailer plug checker and it works too. now all I have to do is ground it.
Ron
173882......173887
Ron Dickey
Images: 787
Postby Alphacarina » Sun Sep 02, 2007 10:18 pm
I've had a 'converter' (powered or unpowered depends on your point of view, because it receives 'power' when the turn signals are on and it puts that 'power' onto the brake lights of the trailer) and it works just fine on 3 or 4 different trailers I regularly pull - Much simpler than adding lights and rewiring 3 or 4 different trailers
Don
Alphacarina
Return to Electrical Secrets
