Side wall Framing
Side wall Framing
Postby mandy » Tue Sep 04, 2007 6:43 pm
I'm still in the planing phase of the TD and one thing that I need more info on is how to do the framing for the side wall. I have seen plenty of profiles but I want to how you all frame your walls; you know to make the insulation sandwich walls. Any pics of your framing is much appreciated.
Thanks Mandy
~Plato~
mandy
Images: 86
Postby Steve Frederick » Tue Sep 04, 2007 6:52 pm
Check out any of my build journals! I've done five, all with sandwich walls.
I use 1/4" ply on each side of a 1-by- frame, with foam board insulation.
You could easily use 1/8" ply to save weight. 1/8" is harder to find, and usually more expensive than 1/4", unless you use luan door skins.
Blessings, Steve
Adirondacks, Upstate New York
Building Journals
Steve Frederick
Custom Teardrop Builder
Images: 29
Postby Weerider » Tue Sep 04, 2007 8:20 pm
Mandy,
Here is a pic of my wall framing. I used 3/4" birch ply for the walls and the same for the wall framing. I cut the sides first and glued and screwed the framing in place. 3/4" foam insulation and then the 1/4" oak ply inside. This is not the way to build a lightweight tear but I am a home builder and just can't make myself build any way but the strongest possible. I will also be towing with a full size Chevy pickup so the weight isn't my first concern. On my next tear (haven't even finished the first one yet) I may go lighter. More pix in my album.
That's just the way I framed mine... I certainly can't argue with the way Steve Frederick builds his beautiful tears.
Howard
The ones who say it cannot be done should stay out of the way of the ones who are doing it!
Weerider
Images: 99
Postby Miriam C. » Tue Sep 04, 2007 8:36 pm
Mandy I highly recommend Steve F's builds they are enormously helpful. I also recommend his CD for builders. Secondly I think JP Locks is great too. http://tnttt.com/viewtopic.php?t=8908
Mine was a mix of the above with some kerfing on the curves. Micro and I both did ours that way.
This is the curved corner with kerfing.
I used the sides as a pattern for the framing. Made it so much easier. Just gotta remember to use wax paper under glued joints. 8)
Postby mandy » Wed Sep 05, 2007 10:45 am
Thank for the Info
Mandy :D
~Plato~
mandy
Images: 86
