Another Cubby door question
Postby Georgeandpat » Tue Mar 15, 2005 3:30 pm
The plans call for the door frame to be covered with 1/2 inch L-molding with one side ripped to 1/4 inch, supposedly, to more easily bend a tight
radius. Well, I left the 1/2 inch as it was, annealed it, and beat the heck out of it with surprisingly good results. However, as I get ready to wrap the door itself with 3/4 inch T-molding I realize that it won't completely cover the L-molding on the door jamb and looks a bit odd. Has anyone else encountered this? Is 1" T-molding available? If so, will it make a 6" radius? Thanks, George.
Georgeandpat
Re: Another Cubby door question
Postby ssrjim » Tue Mar 15, 2005 10:20 pm
Georgeandpat wrote:The plans call for the door frame to be covered with 1/2 inch L-molding with one side ripped to 1/4 inch, supposedly, to more easily bend a tight
I did, the next one I will cut. Kevin needs to add to the plans that it is really so it won't show. You can see it in this link: http://homepage.mac.com/ramjim/PhotoAlbum28.html
93079
ssrjim
Postby norm perkiss » Tue Mar 15, 2005 10:36 pm
Georgeandpat,
I don't have direct experience with the door frame yet, but I've seen several pictures where a ribbon of thin gauge aluminum was layed down first, the width of the door jam. On top of this first course of aluminum, the alumunium angle or T-molding was attached. The gap between the inside and outside is covered in aluminum. I will probably do exactly the same on our doors
Norm.
norm perkiss
Images: 62
Postby Georgeandpat » Tue Mar 15, 2005 11:11 pm
Thanks Norm, and ssrjim- that is exactly what I'm talking about. Your picture says it all but your teardrop looks so good that it doesn't seem to be a big issue. How well does it seal? George.
Georgeandpat
Postby TonyCooper » Wed Mar 16, 2005 12:07 am
I'm just now approaching my skin install and I have obtained 1"x .75" T molding. I'll have to anneal it. I'll report my experience with it.
My Tear Build Site
"No comment"
TonyCooper
Official Pot Stirrer
Images: 35
Postby Georgeandpat » Wed Mar 16, 2005 9:30 am
Thanks Tony, I'm anxious to hear how it goes. George.
Georgeandpat
Postby ssrjim » Wed Mar 16, 2005 8:58 pm
Georgeandpat wrote:Thanks Norm, and ssrjim- that is exactly what I'm talking about. Your picture says it all but your teardrop looks so good that it doesn't seem to be a big issue. How well does it seal? George.
It seems to seal fine. The first time out in Oct. was not done and I got very wet but I have the drip edge and seal in. It's going to the Grand Canyon next week and I'll see how it does.
93079
ssrjim
Postby bdosborn » Wed Mar 16, 2005 11:42 pm
ssrjim wrote:It seems to seal fine. The first time out in Oct. was not done and I got very wet but I have the drip edge and seal in. It's going to the Grand Canyon next week and I'll see how it does.
Hey that's a nice trailer. I have the same 12v outlets that you have. If you peel the blue off the trim plate you'll have a nice silver finish. I really like your fender treatment. I was thinking of putting the T-molding on the inside of the door opening. Anybody else do that?
Images: 806
Postby ssrjim » Thu Mar 17, 2005 7:13 pm
I have 3, there is one for the DVD/TV that you can't see. Yes they are silver.
Since I was cheap and didn't buy better fenders that was what I could do to dress it up.
93079
ssrjim
Postby Georgeandpat » Tue Mar 22, 2005 12:29 pm
I trimmed 1 door with 3/4 inch T-mold this past weekend and was pretty satisfied with the results. I'll post a picture soon. The most important thing, I believe, is to get the gap between the door and frame as small as possible without rubbing during opening and closing. This will maximize the amount of "over-lapping" which should facilitate a good weather sealing. The cubby plans call for a 1/4 inch gap but I think that that might be a little too much. Anyone else here find that to be true?
Georgeandpat
Postby toypusher » Tue Mar 22, 2005 2:20 pm
Don't forget that you need to trim the inside of the door and the inside of the door jam with your sheet aluminum (.032?). And then you put the angle trim on both the door and the jam (most use 1/8" aluminum) and that just about fills the gap of 1/4".
Hope this helps! :)
Kerry
toypusher
Images: 324
Postby Georgeandpat » Tue Mar 22, 2005 3:19 pm
toypusher, If I'm correct, the plans imply making the 1/4 inch gap after the edge trim and corner molding have already been installed on the door jamb. That would make the finished gap too big I think. I agree that a 1/4 inch gap before adding any edge trim or molding should make the final gap about right. George.
Georgeandpat
Postby toypusher » Tue Mar 22, 2005 4:33 pm
George,
Another check of the plans confirms what you said about the door jam being wrapped first, at least that's how it looks. Sill if the door is then made 1/4" smaller and you put the trim on it, the gap will only be approx 1/8" and you still need to get a weather seal in there :shock: That should make the weather seal seal real tight. Just may opinion, as I haven't gotten to the doors yet. My windows and trim were ordered today and hopefully I will working on them soon.
Kerry
toypusher
Images: 324
Postby James (tinbender) » Tue Mar 22, 2005 9:22 pm
Well i just started on my cubbys doors and i made a small mistake on the first door.I switched to .040 metal and it's alitte thicker so watch out for this because you will have to make the gap alittle more than a 1/4"
James (tinbender)
Postby kuffelcreek » Tue Mar 29, 2005 11:50 pm
The reason I made the gap 1/4" is because if the gap isn't big enough, you'll find out after all the trim is cut and installed on both the door and jamb opening. You'll go to shut the door, and it'll hit on the jamb, and after your initial "D'OH!" you'll realize you have to take everything apart, take the door off, and trim a little bit off before re-assembling it, trying to move the screws over 1/16".
On the prototype, the door has sealed fine, sitting out in the driveway four years now.
Kevin
kuffelcreek
