Bearing Buddies
Bearing Buddies
Postby Texas teardrop » Wed Sep 05, 2007 5:00 pm
Does anyone happen to know the size that fits the HF 1450 lb. trailer?
Texas teardrop
Images: 5
Postby Dale M. » Wed Sep 05, 2007 5:28 pm
Why...... The are not the best solution for bearing lubrication... The tend to push grease out rear seal and it splatters all over inside wheel and fender...
A real good bearing inspection and re-lube every couple of years or 20,000 or so miles is simple and a lot less to deal with...
Dale
Dale M.
Images: 18
Postby Geron » Wed Sep 05, 2007 5:59 pm
Ditto.
They are on a used trailer I just bought. The inside of the wheels are a mess.
The bearing buddies are gonna be history.
Geron.
If it's not broken, you're not trying hard enough.
Geron
Images: 173
Postby Texas teardrop » Wed Sep 05, 2007 6:11 pm
Thanks for the information.. I'm not going to use them now.. Saved me a few dollars. :)
Texas teardrop
Images: 5
Postby Alphacarina » Wed Sep 05, 2007 7:03 pm
Forget 'Bearing Buddies' - These are what you really want:
http://www.tiedown.com/aturbo.html
The bearings are lubricated by 90 weight gear oil, just like the rear bearings on your pickup truck
The system isn't under pressure, so the rear seals last forever . . . . as do the bearings
You actually get better fuel mileage too, due to reduced friction - You know that reduced friction means longer life and less heat as well
Don
Alphacarina
Postby Gerdo » Wed Sep 05, 2007 8:18 pm
Don
Those hubs look great.
Texas
I have BBs on my TD, I don't use them. I just pull the hubs apart every couple of years and check the grease and condition. BBs would be OK on a boat trailer that is dunked in water.
Gerdo
Images: 156
Postby packerz4 » Wed Sep 05, 2007 8:40 pm
Dale M. wrote:Why...... They tend to push grease out rear seal and it splatters all over inside wheel and fender...
Dale
yep, and my HF utility trailer has that problem... how do i fix it. i know to take the bearing buddies off, remove castle nut, but then what? how do i fix that rear seal, and where do i get it from? i've read past posts about the seal being an odd size. does Harbor Freight carry the back seal?
thanks in adavance! any info you can send me will help. or pm me if you wanna...
tk
~ Go Packers! ~
www.2bagalot.com
packerz4
Images: 53
Postby brian_bp » Wed Sep 05, 2007 8:52 pm
What Don is saying about oil-bath bearing lube makes sense to me. Dexter offers oil-lubricated bearings on their trailer axles, but apparently only from 5500 lb capacity and up. The hubs are a different part number from the grease-lubed hubs, but the only differences may only be the oil fill port and attachment of the cap (the oil cap may be screwed in and o-ring sealed, versus the interference fit of a grease cap).
A retrofit conversion is an interesting idea. Thanks, Don. :thumbsup:
brian_bp
Images: 9
Postby madjack » Wed Sep 05, 2007 10:33 pm
Dale
tk
tk, if you look in sdtrippers thread at the start of this section and scroll down, you will find a section, detailing most of whats known about bearings and seals...hopefully the info you seek will be there.......
madjack 8)
Postby Airspeed » Thu Sep 06, 2007 12:29 pm
When I replaced the seals in my hubs I just took the old one into Napa,they measured it, walked back to a shelf and set the new ones on the counter.
I had them check if they had bearings while I was at it and they were in stock as well. Mine had no readable markings on them but if you go to an experienced Napa guy he can find the parts easily, at least my Napa guy can. Aaron
Airspeed
Images: 16
Postby Gerdo » Thu Sep 06, 2007 5:28 pm
Airspeed
I don't have a HF frame but for those that do. What are the part numbers or the seal and bearings?
Good find.
Gerdo
Images: 156
Postby madjack » Thu Sep 06, 2007 7:04 pm
Gerdo beware...the HF trailers are manufactured by a number of different manufacturers in different countries and the sizes of bearings and seals do not hold true throughout the different ones...the only way to be absolutely sure of getting the right ones is to remove and measure the old one or bring them with you...Steve Tripp found that even HF themselves had a hard time giving proper sizes or even info on them when he was compiling the info index at the top of this section....
madjack 8)
Postby Gerdo » Thu Sep 06, 2007 7:23 pm
Copy that. Good point.
Gerdo
Images: 156
Postby bobhenry » Fri Sep 07, 2007 6:46 am
Dale
... how do i fix that rear seal, REPLACE IT and where do i get it from?
tk
Save yourself the aggrivation take the old seal to a good automotive parts store and let them cross reference it. If you have a bearing specialist industrial supply store even better. While your there take the inner and outer bearing with you and get a spare set. In case of failure in route Taking 20 minutes to change them on the road beats the alternatives.
Postby goldcoop » Fri Sep 07, 2007 8:51 am
Hey-
Our buddies @ Red Trailers have alot of replacement parts @:
http://www.redtrailers.com/ListItems.asp?cat=7
Don't know if this helps?:roll:
Cheers,
Coop
goldcoop
Images: 32
