Pocket Hole Jig!
Re: Kreg pocket jig vs. biscuit joiner
Postby Podunkfla » Thu Aug 23, 2007 4:35 am
cuyeda wrote:Which technique is more preferred, Kreg pocket hole joiner, or biscuit joiner?
I have a HF biscuit joiner (was gettin' ready for a TD build), but only used it one time. Many people praise the Kreg system, and seems like it makes a strong assembly.
Would the biscuit joiner method provide strength also? After drilling the holes, do you fill it in to make it look purdy, or do you just leave it as is?
The Kreg jig makes very strong joints. I think it still makes sense to use PVA glue too... I always do. I've been using it for more than 5 years now... Prolly built a dozen kitchens and a bunch of other things with it. As for strength compared to biscuit joints? It's a lot stronger... maybe 2 or 3 times the strength! Biscuit joints are good for alighning boards glued up into panels and attaching face frames on cabinets and a few other things. But, pocket screws are much faster and easier. Rockler (and others) sell nice plugs in popular hardwoods like oak & cherry that work very well. When sanded flush they are almost invisable... they are usually on the inside anyway. I do use it for cabinet grade plywood with no problems, but I rely on the Titebond II to really do the holding. JUst a view from a long time user. :thumbsup:
<B>~ Brick
Image...Lots more pix here!
Podunkfla
ol' noodle haid
Images: 5
Postby jp03 » Thu Aug 23, 2007 9:00 am
The metal has more strength too! I am considering the overkill method of pocket screws and side 90 degree clamps. (glueing included) :lol:
jp03
Postby Gambam » Thu Aug 23, 2007 9:42 am
Here is a link to it on Amazon - Free shipping.
http://www.amazon.com/Kreg-K3MS-Master- ... 976&sr=8-1
Gambam
Postby Joanne » Thu Aug 23, 2007 11:02 am
Hi Cliff,
I can see uses for both tools. The biscuit joiner makes nice clean joints that are stronger than a butt joint by itself. If you have a visible joint that doesn't require the extra strength, then the biscuit joint is a good choice.
As everyone has pointed out, the pocket screw joints are significantly stronger, but at the cost of visual esthetics. It really comes down to evaluating the requirements of the specific joint and using the appropriate tool. I primarily used pocket joints in my build but I did have a couple of occasions when the biscuits were needed.
Joanne
New! My Camp Cooking Forum
Project Desert Dawg website
Universal Health Care
Joanne
Queen of Cast Iron
Postby cuyeda » Fri Aug 24, 2007 1:07 am
Joanne, and et al,
I have been slowly acquiring various tools with respect to actually building a TD someday. Amongst the equipment that I already own, these are newly acquired: jigsaw, tablesaw, mig welder, dado blade, biscuit joiner, grinder, dove tail jig, etc... Oh, and Steve Fredericks build manual.
The TD is near the bottom of the project list at the moment. The next project will be building a few cabinets, workbenches and mobile tool carts to help me get organized. I have to find new space in the garage somehow. I just finished the 15' vintage trailer... next 65' Mustang, 22' vintage trailer, 58' Ranchero, and then it will be Teardrop time!
I will add the Kreg pocket tool before the sale ends.
Cliff & Vanessa
cuyeda
Postby rbeemer » Fri Aug 24, 2007 11:28 am
cuyeda wrote:Joanne, and et al,
Cliff,
You can use the Kreg and bisuit jointer on the cabinets as practice before starting your teardrop. THe kreg does make building cabinets alot easier
Rick
If ducks had scales, would fish quack?
rbeemer
Postby KampinOut » Tue Sep 11, 2007 12:37 pm
Sounds like a deal! :)
KampinOut
Postby AmyH » Tue Sep 11, 2007 1:30 pm
I have been using that Kreg pocket hole jig for a ton of the work on my tear, and I absolutely love it!! :thumbsup: The bulkheads went together so quickly. To hide the holes, I simply cover the bulkhead frames with the plywood skins after they are installed, so no holes are visible.
I also put glue on all the joints, even though there is some squeeze-out.
Amy
"...follow humbly whereever and to whatever abyss Nature leads, or else you shall learn nothing." T.H. Huxley
Photo Log
Camping Trips with the Tear
AmyH
*The 300 Club
Postby peggyearlchris » Tue Sep 11, 2007 4:08 pm
:thumbsup: I have both the biscuit joiner and the kreg pocket hole jig. I love them both. I'm using the pocket hole jig the most. :thumbsup: :thumbsup: Peg
peggyearlchris
Images: 56
Postby deputydogrick » Tue Sep 11, 2007 4:52 pm
All my framing is done with pocket joints and titebond II. awsomely fast and strong. Got mine at lowes, cost about $50 to $60 bought some extra screws. set drill bit in my electric drill, and driver bit in my screw gun. Use a visegrip clamp and move. very accurate :thumbsup:
Keep it fun, Move at your own pace, Don't get hurt
"Nurture your mind with great thoughts, for you will never go any higher than you think!" Joel Volk
You should never meddle with dragons...............for you are crunchy and good with ketchup
deputydogrick
Images: 82
Postby steve wolverton » Tue Sep 11, 2007 6:54 pm
cuyeda wrote:I just finished the 15' vintage trailer... next 65' Mustang, 22' vintage trailer, 58' Ranchero, and then it will be Teardrop time!
How do you find the time to enjoy camping with so many projects?
�veni, vidi, vici.�
steve wolverton
Images: 11
Postby ARKPAT » Tue Sep 11, 2007 10:28 pm
deputydogrick Posted: Tue Sep 11, 2007 4:52 pm Post subject:
Same here. Use it on framing and cabinets. Works great. :thumbsup:
Pat
Life is to short always eat dessert first.
ARKPAT
Images: 77
Postby McTeardrops » Thu Sep 13, 2007 12:17 pm
Use good glue with your pocket joints, as I've had some failures of the screws. Also be advised that you still need to use clamps to hold the joint flush and square, as things tend to move as the screws are tightened.
Lenny
[email protected]
I've reached the stage, in life, where my foam has more memory than I do!
McTeardrops
Postby SkipperSue » Thu Sep 13, 2007 12:26 pm
McTeardrops wrote:Use good glue with your pocket joints, as I've had some failures of the screws. Also be advised that you still need to use clamps to hold the joint flush and square, as things tend to move as the screws are tightened.
Yep, what he said. :R
This TD project was the first time I ever used one, I'll never be without one now. 8)
Skipper
SkipperSue
Images: 114
pocket jig
Postby eamarquardt » Thu Sep 13, 2007 1:30 pm
I got mine at a garage sale for $12. A complet kit plus an extra small jig. I love garage saleing (treasure hunting).
Gus
eamarquardt
Images: 150
