I have seen trailers around here, one rocket themed, one with purple wood, and others that belong behind glass, with armed guards (24/7) in the Smithsonian, yea there that good. Mine will be rough around the edges, cause I built it. I am shooting for unique but usable. The rocket themed trailer I would be to afraid to scratch it, to ever think about using it.Miriam C. wrote::? That is a lot of work to get where you are going! I think it will be worth it in the end. Another "art" TTT.Someone needs to start up a museum for alll these artsey thangs.
It was last night.angib wrote:Excellent, del. But do tell us - we're dying to know - if you put the door back in the hole, is it still the same curvature as the body?
Andrew
Thanks to all for the compliments. Uncle Mike last spring when I cut out the wall, I drew out the door (should have drawn it on both sides), and framed it then.Mike C. wrote:Wow del,
That is real purty!!! How xactly did you do that?![]()
Maybe you should put on internet classes on custom designs.![]()
Great job.
