Furnace idea.
Furnace idea.
Postby jeepr » Tue Sep 18, 2007 8:41 pm
The doghouse heater/air conditioner gave me an idea. Tell me if this is silly. Since I would only need the heat late in the year, like October and November, why not make a heater that was external like the doghouse. The heaters in most travel trailers are ducted, I could build a box that sat outside and housed the furnace and run the duct up into the floor. That way if I wanted heat for the trip, I could throw the heater inside and take it with me. That way it won't be taking up valuable realestate inside the tear when I don't need it. I could probably pick up a used furnace at the salvage yard for less than 50 dollars.
I could do the same with an air conditioner, which is only needed here in Michigan for a couple of months of the year. Plus if we are going wilderness camping, I wouldn't need to bring the air conditioner as there is no power.
Any thoughts?
Mike C.
jeepr
Images: 38
Postby jimqpublic » Wed Sep 19, 2007 10:58 am
It would work...
But you would need a propane tank with proper two stage regulator, and a 12 volt source, and an enclosure for the furnace (they aren't rated for exterior use). I bet the $50 furnace would cost $100 worth of fabrication parts to install.
I would think- not having a teardrop myself- but if your trailer is insulated you would mostly want the furnace to warm it up when turning in in the evening and possibly when getting up in the morning- so not a lot of use.
How about the Zodi Hot Vent tent heater? Of course if you had electrical hookups just a cheap electric heater and an electric blanket would solve everything. http://www.zodi.com/web-content/Consumer/zodihotvent.html
Jim
2002 Chalet Arrowhead but always wanted a Teardrop
2 kids and a Dear Wife
http://community.webshots.com/user/jimqpublic
jimqpublic
Postby Bill Fernandez » Wed Sep 19, 2007 11:09 am
Forget it just buy a that dog house thing i have one it great takes up no room and it's central heat and air. works great.
Bill 8) :lol:
Wild Bill The Shoe Man
If The Shoe Fits, Fix it!
<img src="http://tearjerkers.net/forums/album_pic.php?pic_id=46" border="0" />
Bill Fernandez
Images: 119
Postby jeepr » Wed Sep 19, 2007 11:15 am
Bill Fernandez wrote:Forget it just buy a that dog house thing i have one it great takes up no room and it's central heat and air. works great.
Bill 8) :lol:
I would, except I dry camp during hunting season. I would need a 12 mile long extension cord! :lol:
If I run the propane for the stove, all I would need is a quick connect like they use for outside stoves and a battery hookup. Maybe it's a crazy idea and I should just mount the heater like normal.
Mike C.
jeepr
Images: 38
Postby Bill Fernandez » Wed Sep 19, 2007 11:24 am
Well thats a different thing I did't know you were going hunting in that case you could get a genterator and use that or you could find you a sky connection hard to find but worth there sap in gold.
Bill 8)
Bill Fernandez
Images: 119
Postby jimqpublic » Wed Sep 19, 2007 11:37 am
"Propane for the stove" all depends on what sort of stove you're using. If it's the standard campstove it needs tank pressure. If it's an RV stove designed for indoor use it needs a two stage regulator to bring pressure down to 11" WC (Eleven inches of water column or less than 1/2 psi).
If you use a regular camp stove you can get a "propane distribution tree" and hose to connect it to a bulk cylinder. You could also mount the zodi tent heater right on top of this tree. I really like the Century two piece model because it's very sturdy and is only 18" tall when you just use the main part. http://www.centurycamping.com/accessories/hoses/#9060 I got it at Amazon for around $30.
Jim
jimqpublic
Postby jeepr » Wed Sep 19, 2007 11:49 am
I have looked at those Zodi heaters, I love the idea. The only thing I was thinking is that there is no control over the heat. You turn it on and it goes until it runs out of gas (unless I mis-read).
The stove I have is a single side burner off of a BBQ grill, the regulator is off of the same BBQ.
Mike C.
jeepr
Images: 38
Postby mikeschn » Wed Sep 19, 2007 3:27 pm
Get a regular forced air furnace. 12,000 btu. You'll never be cold again. Until you run out of propane that is...
There's a couple pictures here...
http://tnttt.com/viewto ... ace#250993
cookie box heater
Postby Esteban » Wed Sep 19, 2007 4:15 pm
At the SLO Gathering I borrowed teardrop that had a simple, innovative, candle heater. The builder had four metal cookie boxes attached to a side wall in which he could burn candles. The boxes were vented to the outside and to one another. He used hardibacker as a insulator between the boxes and the interior paneling. The tops of the cookie boxes were held shut and air tight with a wing nut on the outside of the cookie tin's detachable top via a threaded bolt from the inside of each tin. I'll post pictures. He said it kept the TD warm in freezing weather. He tested for leakage of combustion air into the interior by burning a scented candle inside a cookie box and didn't smell a scent. It was not cold enough at the SLO Gathering to need to try it out.
edit: Robert, my teardrop "landlord," joined the group and posted more info. below about his simple effective heater. Hi Robert.
Steve - SLO, CA
Esteban
Images: 15
Postby robert spencer » Wed Sep 19, 2007 4:38 pm
Hi , Im new to this site. I have a 5 by 10 micro camper. Not an official teardrop. I built a heater using 8 hour votive candles for a heat source. outside combustion air is provided with a 2 inch vent in a 2 inch pipe. exaust is 2 inch diameter vent in a 2 inch pipe. no inside air is involved for safety. I light 1 or 2 candles,put on the cover and use a big wing nut to hold cover tight in case something bumps it. the metal box radiates heat all night long.It was tested in 18 degree cold this year and 2 candles plus one body was fine.Even though no inside combustion ail is involved I can still crack both windows and be warm. I tested unit with 6 candles to test for oxygen flame out but never use more than 2. Strips of concrete hardiplank spacers between wood walls and metal box (15 by15 by3 deep) keep wall from getting to hot.
robert spencer
Postby jimqpublic » Wed Sep 19, 2007 4:52 pm
With an insulated tear do you even need heat once it's up to temp? My thought on the Zodi was to just bring it up to temp and then shut it off.
Of course I really like the furnace in my Chalet. I just reach my hand out from under the down comforter and flip on the furnace. It seems like a lot of expense, bulk, and complexity for a TD though.
Now the candle heater sounds like a neat idea. I'd like to see pictures.
Jim
jimqpublic
Postby jeepr » Wed Sep 19, 2007 8:23 pm
I'm very interested in the box candle heater too!
Mike C.
jeepr
Images: 38
Postby robert spencer » Wed Sep 19, 2007 9:00 pm
Im no good with putting picture on the net .I will try to get my daughter to do it
robert spencer
Postby mikeschn » Thu Sep 20, 2007 3:42 am
Robert, if you email the pics to me, I can post them for you.
Postby jeepr » Fri Sep 21, 2007 2:05 pm
anyone have any more info on the candlebox heater? I searched online with no luck. It sounds like a great idea! Is the box used tall and skinny or short and fat? Would it need both an air inlet and outlet if there is no fan? It would seem that just vented to the outside would be sufficient.
Mike C.
jeepr
Images: 38
