Stripping side two of the SlumberMAX SO - Could get long
Postby tonyj » Thu Sep 27, 2007 10:55 pm
Steve Frederick wrote:Whenever I do a lot of strips, I use a gang blade set-up..
Two 7-1/4" blades on the arbor, with a shim in between. I made a zero clearance insert from 1/4" ply..raised the running blades through it.
I cut two strips each pass.
Steve--are those dado blades or circular saw blades?
tony
tonyj
Images: 160
Postby Steve Frederick » Fri Sep 28, 2007 1:22 pm
Just regular circ-saw blades. I did use the center of my three wing molding head as a shim once, Image
two or three flat washers another.
:thinking: You know, a dado set without the chippers would work also!
Didn't think of that, since my dado setup is a "wobbler".
Blessings, Steve
Adirondacks, Upstate New York
Building Journals
Steve Frederick
Custom Teardrop Builder
Images: 29
Postby tonyj » Fri Sep 28, 2007 1:30 pm
Steve, thanks. My thinking was that my dado blades are sharp, my tablesaw blades aren't! :lol:
I guess with the dado blades without the chipper, there might be just a little more waste than with a thin-kerf blade. But your 2 blade setup would have made my project 2 weeks ago faster when I ripped a bunch of 1/4 inch strips for my galley countertop.
tony
tonyj
Images: 160
Postby Juneaudave » Sat Oct 20, 2007 9:52 pm
Boy...I need some closure on this thread...but I have a couple other things that I want to show that may be usefull...
First off...about ripping cedar boards. Cedar comes in an amazing variety of colors and an individual board may change colors thoughout its length. The range of colors can go from a very light cream colored to a dark tan, to a deep red. One of the things that the homebuilder can do is index your strips as they come off the board (BTW...many of the best kayak shops that supply kits now number their boards as they are ripped to keep them in order.) I tend to lay them out in order that I rip them and then bundle them so I have a sense on what I have when I set up for stripping!!!
Some stripping designs are random, but I have always thought that the best were in some sort of pattern. On side two, I tiried to do something similar to side one. I ran a bunch of the darker strips along the line of the window...and used a 1/2 cut lighter strip to transition. It's a little hard to see on the raw wood...but once a finish is applied the contrast will be substantial!! Phew...here's a pic of side two stripped!!!
Next...I'm going to lay that side back down...use Roly's beltsander tutorial, fill the cracks, block and finish...we'll see how it goes!!!
Juneaudave
Juneaudave
Images: 380
Postby Sonetpro » Sat Oct 20, 2007 9:56 pm
WOW :o
:thumbsup: :thumbsup:
Sonetpro
Images: 107
Postby Chaotica » Sat Oct 20, 2007 11:26 pm
Damn.
Ed
Chaotica
Images: 22
Postby Classic Finn » Mon Oct 22, 2007 5:05 pm
:o Yupper :o :shock: Way Cool...Beautiful :applause: :applause: :applause: :applause: :applause:
Your amazing for sure.. I cant wait to see it done..
Im speechless... :applause: :applause:
Classic Finn :thumbsup: :thumbsup: :thumbsup:
Classic Finn
Midnight Sun Voyager
Images: 146
Postby Juneaudave » Mon Oct 22, 2007 8:55 pm
Thanks guys...Boy, was I happy to get that last side stripped. It really took me forever and I'm a little burned out on TD sides for the time being. Happily, I'm in for a welcome break from work and teardrop trailers!!! On Sunday, I'm flying out on a float plane to a FS cabin for a week of hunting and cutthroat trout fishing with a couple of friends. Yippee!!!!
Juneaudave
Images: 380
Postby Mike C. » Mon Oct 22, 2007 10:16 pm
That is really fantastic. :thumbsup:
I agree with Heikki, I can't wait to see it finished.
It is beautiful. :applause: :applause:
Uncle M ( Mike )
Mike C.
our Uncle M
Postby Tcurr » Tue Oct 23, 2007 7:17 am
That looks amazing. I am sure that was a ton of work but definately worth the time. Wonder if I can talk Mamma into letting make another 8)
My Idea of plans are a tape measure, a saw and a dream.
Tom & Brenda
Westerville, Ohio
Tcurr
Images: 92
Postby Steve Frederick » Tue Nov 13, 2007 7:43 pm
Bump! Dave, how's it goin'?
I'm Jonesin for some updates! :worship: :worship:
Blessings, Steve
Building Journals
Steve Frederick
Images: 29
Updates
Postby prohandyman » Tue Nov 13, 2007 7:55 pm
So am I. Dave sure has inspired me! 8)
Dan
prohandyman
Images: 785
Postby Jst83 » Tue Nov 13, 2007 8:54 pm
:shock: Wow you all are making me :envious:
These sure are some beautiful stripper Tears that are showing up
Nice work
Jst83
Images: 215
Postby Steve Frederick » Tue Nov 13, 2007 8:58 pm
Jst83 wrote::shock: Wow you all are making me :envious:
Nice work
Maybe we could start a "Strip-Show?" :roll:
Blessings, Steve
Building Journals
Steve Frederick
Images: 29
Postby Juneaudave » Tue Nov 13, 2007 9:03 pm
Yuk...I'm back on the road again...before I left, I dry fit the bulkheads and marked some stuff. Next weekend, if I get home, I'll drop the sides one last time, do some welding I need to do to finish up... then fill, sand, epoxy that last side and put up the sides for good. That will make me happy!!!! Everything is cut for the skins, hatch, spars etc. Its just a matter of finding time.
Juneaudave
Images: 380
