POOL LINER
POOL LINER
Postby MARVIN THOMPSON » Sat Sep 29, 2007 7:37 pm
QUICK GUESTION SWIMMING POOL LINER GLUE TO ROOF. GOOD IDEA OR BAD IDEA IT,S A FEEBIE :twisted:
MARVIN THOMPSON
Postby Alphacarina » Sat Sep 29, 2007 8:29 pm
I would glue it to the roof - The weight of the water in the pool should keep it securely in one place, but with a mobile swimming pool, you can't be TOO sure :laughter:
Don
Alphacarina
Postby madjack » Sat Sep 29, 2007 10:08 pm
...I'd pass...too much slosh...doanchano :D :lol: ;) .......but seriously, I'd pass...don't know about the UV resistance in direct sun(possibly) OK...what type or whether or not to use adhesive to bond it...I have seen old liners left out in the weather and they simply deteriorate into large confetti..............
madjack 8)
liner
Postby irondance2003 » Sun Sep 30, 2007 4:30 am
Over here in OZ we get huge outdoor signs on the side of major roads that are plastic bonded stuff very UV resistant very flexable I got one a while back and used a section under the last Teardrop's hatch paino hinge ,,never a leak and never cracked either and as far as I know is still working well.
I kept a section for an annex one day as the original was 40ft x 10 ft cost me $15 section I kept is a photo of the Ground Zero Firemen.
It is heat sealed and I had thoughts of useing it as a layer under the outer skin but never camp anywhere cold enough to warrant any insulation.
Build with CARE, TIME will tell.OH and I changed my website in dec07
irondance2003
Images: 24
