HELP! we just busted our new waffle iron!!
Postby daveleb55 » Sat Sep 01, 2007 9:14 pm
A neighbor came by and we said "hey, look at our cool antique waffle iron!" Oops <CRASH> "Oh futz!!!!" :cry:
Does anyone know if it's possible to repair this? It's an old Griswold #8, makes beautiful waffles. It'd be a shame to have to retire it so soon. :x
Dave & Kathleen :cry:
"Get off the #@$% computer and GO CAMPING!"
daveleb55
Images: 203
Postby Kurt (Indiana) » Sat Sep 01, 2007 9:18 pm
Don't know for sure, but a good "cast "welder should be able to fix the Iron.
If all else fails, send it to me and I'll see if one of our welders can fix it. Show me more pictures of the break.
CRA2023 Web Site
"Wall of Fame 2011-2021"
Kurt (Indiana)
Images: 178
Postby jeepr » Sat Sep 01, 2007 9:24 pm
hhhhmmmmm..
Well, it's possible to weld cast iron. You may have to call around to find a place that will do it. You have to heat the entire piece, either in a stove or with a torch, then it can be welded.
Mike C.
jeepr
Images: 38
Postby pgwilli » Sat Sep 01, 2007 9:39 pm
When I bought a cheap copy iron that didn't have the "hold open" ears on the rotating sphere, Rainjer suggested that I drill and pin the two halves together.
Might work for you, depending on how the broken pieces fit together...and how you could index the hole for the pin on the two pieces to make sure they were on the same axis... :thinking:
Paul, Norma & the Girls
2014 Escape 21
2006 Chevy Trailblazer
pgwilli
Images: 75
more pics
Postby daveleb55 » Sat Sep 01, 2007 9:46 pm
Kurt (Indiana) wrote:Don't know for sure, but a good "cast "welder should be able to fix the Iron.
Kurt:
Heres a few more pics, I hope these are clearer
Dave & Kathleen
daveleb55
Images: 203
Postby Kurt (Indiana) » Sat Sep 01, 2007 9:51 pm
Dave, search the area for welders that can do cast iron. Let me know if you find one.
http://www.muggyweld.com/castiron.html Here is one, but I don't know their location. It would be worth a call.
CRA2023 Web Site
Kurt (Indiana)
Images: 178
Postby Ma3tt » Sat Sep 01, 2007 10:12 pm
I had a friend drop a 12 inch oven shattered like a piece of tile. I feel your pain! good luck with the repair. I have welded cast iron and it is a bit different, I would feel safe plugging a hole, or crack but a structural part, I don't know.
Be Good
1967 Siesta del Sobrino "Standy"
If you lived here... you would be home by now.
http://www.Camp-Cook.com
Ma3tt
Dutch Oven GURU
Images: 179
Postby doug hodder » Sat Sep 01, 2007 11:44 pm
I'm sure others might disagree with this approach, but for what it's worth...clamp the 2 iron halves together, clamp the broken piece in place, grind a weldable surface at the break and have a local welder hit it with nickel rod. I've welded up broken exhaust manifolds that way. It's not structural, just keeps the 2 irons in place so you can open them and rotate. Just an idea. Doug
Postby Podunkfla » Sun Sep 02, 2007 12:11 am
Dave & Kathleen... Like Doug said... a welder that is good with nirod (nickel) could weld it. It will still look like a patch as the nickel will be bright. Prolly a better idea is just buy this one on ebay without the base... It will prolly go for $9.95... cheap! It's a Wagner #8 but should fit your base. Good luck.
http://tinyurl.com/2j58ft
Another one may go cheap too:
http://tinyurl.com/2nav2a
<B>~ Brick
Image...Lots more pix here!
Podunkfla
ol' noodle haid
Images: 5
Postby pgwilli » Sun Sep 02, 2007 12:40 am
Brick-
The first one sure looks like the fake I have on my back porch...
Dean sez the original Wagners have the date in script, not block letters...BBW
2014 Escape 21
pgwilli
Images: 75
Postby Podunkfla » Sun Sep 02, 2007 1:32 am
pgwilli wrote:Brick-
Now that it could be??? I've never seen a fake, but I know they are out there. :(
<B>~ Brick
Podunkfla
ol' noodle haid
Images: 5
Postby Dean in Eureka, CA » Sun Sep 02, 2007 10:09 pm
Paul,
Dave's is a Griswold, not a Wagner.
Dave,
Kevin A would be a good guy to ask IMO...
Dean in Eureka, CA
The Fogcrawler
Images: 69
Postby caseydog » Sat Sep 29, 2007 6:55 pm
This is a real longshot, but the folks at JB Weld say you can fix an engine block with the stuff. If nothing else works, and you are going to give up, it might be something to try.
CD
My build journal is HERE
caseydog
Images: 515
Postby Podunkfla » Sat Sep 29, 2007 9:09 pm
caseydog wrote:This is a real longshot, but the folks at JB Weld say you can fix an engine block with the stuff. If nothing else works, and you are going to give up, it might be something to try.
CD
It is true... You can fix a crack in an enginge block with JB-weld. But in this case, there is just not enough surface area to make a very strong bond.
Now... For the craziest use of JB-weld: I replaced a high dollar Toyo toilet with a broken mounting flange for a customer. He gave me the old one. JB-weld is holding fine after two years. You can't see the crack i fixed. I'm way too cheep to ever buy a $500. toilet... But I'll sure take one for free! ;)
<B>~ Brick
Podunkfla
ol' noodle haid
Images: 5
Postby Arne » Sun Sep 30, 2007 7:18 am
I would braze it, not weld it.
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Return to Cast Iron
