Building over the frame edges...
Postby agileaction » Wed Oct 17, 2007 12:55 pm
I have a question for those who have designed and/or built a TTT. I have seen at least one TTT that was built on the Harbor Freight trailer, but the floor was extended to either side such that the wheels were underneath the trailer vs. on the outside.
Do you need the chassis to have supports that extend to the outer edge of the wheels to accomplish this, or can you accomplish it with the floor structure, using the standard 'box' of the Harbor Freight (other other manuf.) trailer?
Hopefully my question makes sense.
agileaction
Postby jeepr » Wed Oct 17, 2007 1:10 pm
Mine extends beyond the sides of the trailer. Not so much at the sides, but more at the front and rear. Just the floor structure holds it up.
Mine has not been on the road yet though.. :lol:
Mike C.
jeepr
Images: 38
Postby bobhenry » Wed Oct 17, 2007 1:53 pm
Image GET A COUPLE OF THESE ...
AND MAKE 1 OF THESE.....
THEN THROW SOME OSB ON IT
Postby bobhenry » Wed Oct 17, 2007 2:04 pm
Seriously the hf axle assembly is 48" wide and the handail was 24" top of top rail to bottom of center rail so with top of rail to top of rail they measured out at 48" like it was ment to be. All I used was the axle assembly and the tongue by prying it open enough to slip it over the handrail and weld it in.
Took Chubby 700 miles this week and was a bit nervous as it was literally our first time on the road. All went well and I had folks at rest stops and gas stations wanting to look it over. I probably looked like a proud papa.
Postby agileaction » Wed Oct 17, 2007 2:26 pm
Well, you actually did add on the supports out to the sides, so that's not really what I'm proposing/asking.
Anyone else?
agileaction
Postby coonrebel » Wed Oct 17, 2007 4:58 pm
This is what I did.Image
andImage
coonrebel
Images: 186
Re: Building over the frame edges...
Postby steve wolverton » Wed Oct 17, 2007 8:32 pm
agileaction wrote:I have a question for those who have designed and/or built a TTT.
:twisted:
I would say it would depend on how wide you're going. The Puffin (my Tiny Travel Trailer) is 6' wide on a 4' trailer w/o extensions. I have 3700+ miles, and 50+ days camping in it.
coonrebel - That's slick! Did you make those, or buy them. I like that. :thumbsup:
�veni, vidi, vici.�
steve wolverton
Images: 11
Postby coonrebel » Wed Oct 17, 2007 8:47 pm
I made them out of 3/4" and 1" angle iron.
coonrebel
Images: 186
Postby del » Thu Oct 18, 2007 10:05 am
If you look at how a mass produced travel trailer is made (and how little bracing is used), and how most people brace (a little overkill is not bad) the over hang. The truth is somewhere in the middle. The joint at the floor, to the wall, becomes very critical.
del
del
5000 Club
5000 Club
Images: 410
