Home made wheel chocks
Postby Sam I am » Wed Oct 17, 2007 9:03 pm
I've been using scraps of lumber for wheel chocks on my tear, so I decided to make some better ones. They're pretty simple. Each one is made of three pieces of 2x4 cut on an angle and glued together. A 6" carriage bolt runs through them and attaches to a 1/2" plywood tie bar. A 1 1/2" long slot on one end of the bar lets you slide them apart, and slip them around the wheels. then push them tight against the wheel and tighten the wing nut. Here are some pics.
I think they'll work!
Sam
Sam I am
Images: 106
Postby tonyj » Wed Oct 17, 2007 10:19 pm
Pretty slick. :thumbsup:
I think I have some scrap that would fill the bill. Thanks for the design.
tony
tonyj
Images: 160
Postby doug hodder » Wed Oct 17, 2007 11:06 pm
Thanks for the idea Sam....I've been using hunks of firewood, or rocks! Doug
Postby Nitetimes » Wed Oct 17, 2007 11:26 pm
Wheel chocks??? Never tried 'em. 8) 8)
Rich
- Thomas Jefferson -
Nitetimes
7000 Club
7000 Club
Images: 194
Postby ARKPAT » Wed Oct 17, 2007 11:56 pm
I got my idea from the '85 F-150 manual.
4" x 4" the is 12" long cut in half with a 45 degree cut.
Use 18" of chain and two 3/8" x 1 1/" collered deck screw to attach to the same side of the now two blocks. Place at the front and back of the wheel and apply the chain and screw to the wood blocks for a snugg fit.
Same as
Sam I am Posted: Wed Oct 17, 2007 9:03 pm Post subject: Home made wheel chocks
Sam
Pat
PS I'll have to take pictures and I still have both the truck and the blocks. :D
Life is to short always eat dessert first.
ARKPAT
Images: 77
Postby mikeschn » Thu Oct 18, 2007 5:58 am
Nice Chocks... I'll have to make some!
Postby Tcurr » Thu Oct 18, 2007 7:21 am
Nice chocks I will have to make a set.
My Idea of plans are a tape measure, a saw and a dream.
Tom & Brenda
Westerville, Ohio
Tcurr
Images: 92
Postby Joseph » Thu Oct 18, 2007 8:03 am
Nitetimes wrote:Wheel chocks??? Never tried 'em.
We camped on an asphalt slab one time that had a slight incline. Without chocks we'd have been rolling down the road.
Joseph
Joseph
Teardrop Pirate
Postby Nitetimes » Thu Oct 18, 2007 8:07 am
Joseph
:lol: :lol: :lol:
Might have been an interesting ride in the middle of the night! 8) 8) :lol: :lol: :lol:
Rich
Nitetimes
7000 Club
7000 Club
Images: 194
Postby Dixie Flyer » Thu Oct 18, 2007 8:09 am
Those are pretty nice. Look good too.
Here's how I did mine. (Sorry no pics, maybe you can see in the album if you look close)
Take a 4x4, cut at a 45 degree angle, screw in eyebolts in each one, fasten rope to each eye bolt. Presto! Two pair of chocks! :lol:
I poked it with a stick..........
Dixie Flyer
Images: 46
Postby b.bodemer » Thu Oct 18, 2007 8:21 am
very cool idea.
Barb
b.bodemer
Images: 328
Postby cuyeda » Thu Oct 18, 2007 6:24 pm
Nice home brew! Looks like it will keep the tires secure!
I bought two heavy duty rubber chocks at Wally mart. The nice feature is that it is made of thick rubber, instead of the hard plastics. When in use the rubber surface grips better against the tires. It also grips the pavement or dirt so much better than the plastic chocks. I carry a rubber mallet just to give it a little tap to wedge it in.
Cliff & Vanessa
cuyeda
Re: Home made wheel chocks
Postby Alphacarina » Thu Oct 18, 2007 9:25 pm
Sam I am wrote:I've been using scraps of lumber for wheel chocks on my tear, so I decided to make some better ones. They're pretty simple. Each one is made of three pieces of 2x4 cut on an angle and glued together. A 6" carriage bolt runs through them and attaches to a 1/2" plywood tie bar
What is the advantage of having the tie bar inside the wheel where you have to bend your wrist around and tighten the wing nut only by feel?
Seems like it would work just as well (and be easier to use) with the tie bar on the outside?
Don
Alphacarina
Postby Mary K » Thu Oct 18, 2007 10:36 pm
Brilliant
Mk
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby Sam I am » Fri Oct 19, 2007 7:44 am
Don, they could be used with the tie bar inside or outside of the wheel. I showed them inside strictly because I thought they looked better that way. You're right, it is easier to tighten them up with the tie bar in front.
Sam
BTW, thanks, all for the compliments on my design! :)
Sam I am
Images: 106
Users browsing this forum: Jimbodub and 5 guests
