doug hodder wrote:I'm an electrical dope...what is the thing called that I need to convert a regular brake/turn into a regular brake for the 3rd taillight that I want to put on the hatch on my tear? and are they available at an Autozone or Kragens? Doug
Steve_Cox wrote: Anyway it seemed the LED's in the circuit didn't make enough load to fire the logic module to make the 3rd light work. got from JC
There isn't any problem using the flat 5 wire connector for that purpose either - All your other trailers with the flat 4 wire plugs will still plug into the 5 wire half on the tow vehicle . . . . the 5th connector in the plug for the CHMSL just doesn't connect to the 4 wire half on the other trailers. Using the 5 prong plug makes it nice because there is only one connection to makeBrwBier wrote:I can tell you from experience that taping into the chmsl (center high mount stop light) as it is called in all the shop manuals I have seen, is not a problem. I ran a separate wire through a separate plug from the terminal in a plug in the left rear of my Venture van to the chmsl on my teardrop. That way it can be used by any tow vehicle with a flat four plug, it just wont have the chmsl
Users browsing this forum: Bing [Bot] and 8 guests
