Super Sized weekender but still a ttt???? mike?
Thanks.
Postby beevel » Mon Jun 18, 2007 8:16 pm
1/4 inch it is.
Hopefully my trailer will sell tonight and then I will start my shopping spree.
Thanks everyone.
beevel
Postby Jeeper92 » Mon Jun 18, 2007 8:32 pm
mike you nailed it, now im gonna build it like the puffin out over the wheel wells, but with the weekender lines, looks soo cool!!!!!!!!! Hows about adding a propane storage area and an ac, very very nice, im gonna use the side of it to cook on, ill use the table that the puffin has but ittl be longer. The propane hook up will be on the side where the table is gonna be, soo i can just take the grill out and cook on the table
Jeeper92
oooooo
and im gonna add an awning to the side
Jeeper92
Postby sseaman » Mon Oct 22, 2007 8:24 pm
mike, i like the looks of the 6x10 weekender you drew up( you have some great cad skills) what is the thought on a drop floor of a few inches and lowering the top height some? i am towing with a landcruiser so width and height isnt a major problem.
sseaman
Postby sseaman » Tue Oct 23, 2007 9:02 am
mike, one more thing, do you have any additional views of that drawing, man th more i look at it the more i like it. thinking of even rounding it off a bit.
sseaman
Postby mikeschn » Tue Oct 23, 2007 5:34 pm
No I don't have any more drawings. What you see is all I have. But you can build it with Weekender construction techniques
http://www.mikenchell.com/weekender/
or Benroy construction techniques (up there in the menu)
Postby sseaman » Mon Oct 29, 2007 8:43 pm
Mike, the wheel size would have to be 13" to 15" to look right, wouldnt you think? i sold the old popup this weekend, so i will not start daily checking craigslist for trailer options
sseaman
Postby mikeschn » Tue Oct 30, 2007 5:20 pm
I think anything 13" and up would be fine. I have 13" on my ET, and it looks okay.
Postby sseaman » Tue Oct 30, 2007 9:00 pm
what is the height of your et, im thinking i want something to look tough, but also fit in the garage
sseaman
Postby sseaman » Thu Nov 08, 2007 10:39 pm
mike, do you think there would be a big towing difference in the 6x10 weekender versus something like the baja benroy?
sseaman
Postby mikeschn » Fri Nov 09, 2007 4:55 am
I don't think you would notice the difference between the weekender and the benroy.
The weight could be about the same, and the cross section area could be similar.
I'll go out and measure the height of the ET for you this evening.
Postby sseaman » Sat Nov 10, 2007 7:26 pm
thanks, what size were the tires on the baja?
sseaman
Return to Member Designs
