Podunkfla wrote:Brick, that one has some possibilities without the wheels. I like the one hand crank but can't see how it works. I want a 48" x 96" table top plus hardwood edging. I also need to be able to move it with my pallet jack depending on the size of the project I'm working on. I place my work bench in two or 3 spots depending on what I'm making.
Danny... It works just like a big version of a scissor jack. The crank end needs a thrust bearing that lets the threaded rod turn. The other end is nothing more than a large captive nut in a pivot between the legs. Something like 3/4" allthread should work just fine for what you are contemplating. The handle end could be just a used wratchet extension? Then you could use a wratchet, speedwrench, drill motor or whatever to crank it with.
Find someone throwing away a worm drive garage door opener and you can forget the crank !
