How Much Aluminum?
How Much Aluminum?
Postby KZ76017 » Thu Mar 31, 2005 10:15 pm
How many sheets of aluminum did it take to cover your tear?
:thinking:
I bought 4 (4X8) sheets.
I think I'm going to be one short since it's 68" wide.
Think I'll use some diamond plate on the front though. That should make up the difference.
KZ76017
Images: 63
aluminum
Postby David Beckett » Thu Mar 31, 2005 10:33 pm
If you count two sheets for the sides, that leaves you 2 for the top, front, and back. Better get one more. Mine is wider than 48 also. Much more expensive to build.
David Beckett
Postby SteveH » Thu Mar 31, 2005 11:04 pm
I covered mine with lots left over with four sheets, but my tear is 60" wide, and I bought 5' X 12' aluminum. It was the only 5' wide in San Antonio that wasn't painted.
SteveH
SteveH
Images: 42
Postby BILLYL » Fri Apr 01, 2005 10:36 am
So just double checking - For a Cubby I can order 3 - 4x10 (for the sides and top) and 1 4x8 for the galley.
Just need a sanity check..............
Thanks
BILL
"If your children ever find out how lame you really are, they'll
gonna murder you in your sleep...." Frank Zappa
BILLYL
Postby Geron » Fri Apr 01, 2005 10:41 am
I picked up four 4x10x.040 just to be on the safe side. I'll have leftover but someone suggested using the left over to line the galley. Anybody tried this for the galley?
Geron
If it's not broken, you're not trying hard enough.
Geron
Images: 173
