Progress before post - that's the order.
Nest'r build continues...
Postby LesterS » Sat Oct 27, 2007 9:11 pm
I managed to roll it outside and take few more pix.
Just barely clearing the door frame -- but it made it. :o
Things are coming along though...
Even though I know every parent thinks their kid's handsome; I like this profile, it took me a while to settle on one profile, but this one's gown on me. :thumbsup:
As far as a vent goes, the plan now is to mount it behind the high point of the roof over the table area, but yes, it may have to be installed after exiting the garage.
Lester
Bristol, TN
Still buildin' on teardrop time.
Build thread started here: http://www.tnttt.com/viewtopic.php?t=19404&highlight
And continued here: http://www.tnttt.com/viewtopic.php?f=50&t=41005
Gallery: http://www.tnttt.com/gallery/album.php?album_id=1371
LesterS
Images: 131
Postby halfdome, Danny » Sat Oct 27, 2007 9:18 pm
Looks great :thumbsup: . You must be building a standie. :) Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby Juneaudave » Sat Oct 27, 2007 9:56 pm
That really looks good Lester!!! :applause: :applause:
Juneaudave
Images: 380
Postby aggie79 » Sun Oct 28, 2007 9:21 am
Lokks fantastic! Your design is very close to what I have in mind. I'll be following your build closely. Thanks for posting.
And more pix
Postby LesterS » Tue Nov 06, 2007 4:01 pm
I got started on the interior, and now have some inside panels up along with the structure that'll support the bed/dinette.
I tinkered a bit with the rear rocker framing some too...
So, it's coming... little by little.
Lester
Bristol, TN
LesterS
Images: 131
Postby bgordon » Thu Nov 08, 2007 1:52 am
Hi,
Your build looks good!
What (white) material are you using to cover (skin) the inside of the trailer?
Barrie
Keep moving forward.
Psalm 1:1-3.
Build Journal: bgordon's 5 week cardboard & fiberglass build
http://www.tnttt.com/viewtopic.php?f=50&t=38781
bgordon
Images: 122
Postby toypusher » Thu Nov 08, 2007 6:48 am
Great progress. Looking real good!
toypusher
Images: 324
Postby AmyH » Thu Nov 08, 2007 12:03 pm
WOW Lester! That is looking great!! :thumbsup: And it is coming along so fast! I can't wait to see it come together!
Amy
"...follow humbly whereever and to whatever abyss Nature leads, or else you shall learn nothing." T.H. Huxley
Photo Log
Camping Trips with the Tear
AmyH
*The 300 Club
Postby elmo » Thu Nov 08, 2007 2:05 pm
Very nice...I like it alot! Can't wait to see it when its done. :thumbsup:
It's scary when you start making the same noises as your coffee maker.
elmo
Images: 216
'White' Material for interior
Postby LesterS » Thu Nov 08, 2007 4:08 pm
The white panels on the interior, I'm almost ashamed to disclose. :oops:
They are inexpensive (repeat cheap) "oak" prefinished 1/8" thick paneling.
I place quotes around the word oak because the only thing oak about it, is it has an oak-like grain pattern under the white finish.
I bought the material at Lowe's, for about $13 a sheet. The main reason I bought it was the fact it was 1/8" thick, lightweight, and cheap.
I won't be able to varnish and show off any wood grain, but the primary objective for its selection was the weight, this stuff was like 10 or 12 pounds a sheet! after trimming to length the eleven sheets will proablably only add 75 to 85 pounds to the camper! :thumbsup:
For the outside, I'm currently scanning local lumber yards and big-box stores for more 1/8" thick AND lightwieght material. If I have to, I'll go 1/4" thick, but my goal is 1/8". (I'm currently contemplating door skin luan that's 1/8" x 3' x 7') :thinking:
I appreciate the compliments, and I'll try to add pix that show some continued progress.
Oh yeah -- and it's great what a low-rez picture will hide inthe way of errors and flaws!
Lester
Bristol, TN
LesterS
Images: 131
Postby mikeschn » Thu Nov 08, 2007 6:10 pm
Looking good Lester.
How high are the sidewalls? About 60"?
It's going to look nice when it's done, albeit a bit familar! :o
Postby aggie79 » Fri Nov 09, 2007 8:58 am
Could you post the length and width also, please?
Postby SkipperSue » Fri Nov 09, 2007 9:06 am
Your build reminds me of a giant balsa wood model. ;)
Looks great! :thumbsup:
Skipper
SkipperSue
Images: 114
Postby Miriam C. » Fri Nov 09, 2007 10:17 am
:applause: :thumbsup: :applause:
For the outside, I'm currently scanning local lumber yards and big-box stores for more 1/8" thick AND lightwieght material. If I have to, I'll go 1/4" thick, but my goal is 1/8". (I'm currently contemplating door skin luan that's 1/8" x 3' x 7') Thinking
If you check the real lumber yards they should be able to order you 1/8 Birch (4x8) and you have to be sure they order 4x8. Got mine for $14.00 but they are very thin veneered. You really have to not sand much. They do bend really well though.
The inside panels look great. Nice an light. :thumbsup:
Another long-winded respose.
Postby LesterS » Fri Nov 09, 2007 3:28 pm
It's going to look nice when it's done, albeit a bit familiar!
There's the profile as it is being built. (Give or take an inch underneath).
The shape itself was driven by several design parameters...
84" opening on the garage door.
72" for interior headroom (over the dropped floor).
Fit to an extended HF 4x8 trailer (extended to 114")
About 65" wide for both fitting a queen size sleeping area AND
narrow enough that I wouldn't need extended mirrors on the car.
Sitting headroom over the dinette area.
Standing headroom in the 'head'.
Ground clearance similar to the axle clearance.
I had the whole shape laid out with just arcs and started the build when I realized I could get a bit more headroom over the dinette area if I changed the top curve to an ellipse. A benefit of the change made it where I could draw the profile now from inside the garage! (The original profile included a 120” arc radius!)
Strangely enough, when laid out, it became basically a big Benroy clone. - Can you say Baja?
(Ya know, they say imitation is the sincerest form of flattery.)
To scavenge every bit of interior height I could, I placed the plywood deck (floor) right on the trailer frame, and placed the wooden cross members in the same plane as the trailer cross members.
The deck itself is only 15/32" thick (and plenty strong).
The only thick "deck" is the bottom of the drop well, it is 23/32" material, with no frame.
All of the structure is regular 1x2's and the curves are cut from the same 23/32" plywood. The side framing is biscuitted and glued, where the spars are glued and screwed.
As far as a "balsa wood model", the principle is the same. The curves of the profile only have straight runs front and back, and they're kept as short as possible. The curve lends great strength to the construction, and a secondary benefit is that it will shed rain without any flat areas to collect water.
I have a long way to go, but so far, it’s been smooth, and I’m having fun.
I’ll try to keep the photos in the album up to date, and post often if I can.
I appreciate the compliments, especially from a group as talented as we have here!
Lester
Bristol, TN
LesterS
Images: 131
Return to Member Designs
