the jelly belly build
Postby Mary K » Fri Nov 09, 2007 12:19 pm
Del, you are doing an amazing Job!! This has been so much fun watching!!!
You deserve a dance!!!
Mk
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby doug hodder » Fri Nov 09, 2007 6:53 pm
That's shaping up nicely Del!!! What's the plan on the window, lexan? Doug
Postby del » Fri Nov 09, 2007 11:51 pm
Mary K wrote:Del, you are doing an amazing Job!! This has been so much fun watching!!!
Mk
Thanks Mary K
del
del
5000 Club
5000 Club
Images: 410
Postby del » Sat Nov 10, 2007 12:12 am
doug hodder wrote:That's shaping up nicely Del!!! What's the plan on the window, lexan? Doug
I already bought it, here is what I remember, it is bendable, and clear.
del
del
5000 Club
5000 Club
Images: 410
Postby del » Sat Nov 10, 2007 12:52 am
Andrew remember when you asked me if the door held its shape when I cut it out?
Note the two cables are under tension.
I did finish sanding the body, no it is not perfect, but close enough for this trip.
I worked more on the floor.
del
del
5000 Club
5000 Club
Images: 410
Postby Classic Finn » Sat Nov 10, 2007 1:58 am
Ohhh Wow.. Thats a nice looking Yelly Bean says we all.. :applause: :applause: :applause: :applause: :applause: :applause:
Gee you are talented Del..
Your going to be having lots of people lining up for a tour once its done so hope you are ready for it.. ;) :thumbsup: :thumbsup:
Very Nice
Classic Finn
Classic Finn
Midnight Sun Voyager
Images: 146
Postby angib » Sat Nov 10, 2007 7:09 am
del wrote:Note the two cables are under tension.
Fiberglass would be an ideal material to make a permanent fix of this - pull the wires a bit tighter than normal to allow for a little spring-back and then laminate over a couple of ribs to fix the shape.
Fit a front plate between the two ribs and there's the magazine rack you always intended to fit to the trailer.....
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby Tcurr » Sat Nov 10, 2007 8:03 am
Looking gret Del. It is really coming along nice.
My Idea of plans are a tape measure, a saw and a dream.
Tom & Brenda
Westerville, Ohio
Tcurr
Images: 92
Postby peggyearlchris » Sat Nov 10, 2007 10:12 am
Wow Del! Just awesome to see your build. :thumbsup: :thumbsup: :applause: :applause: Peg
peggyearlchris
Images: 56
Postby del » Sat Nov 10, 2007 10:42 am
Andrew
Magazine rack :thinking: :thinking: . I hoping this fix will last till spring. Then insulate and cover the void completely.
Thanks del
del
5000 Club
5000 Club
Images: 410
Postby del » Sat Nov 10, 2007 10:45 am
And a message for everyone else who drop by, you help me stay motivated, thanks. The next week and a half will be frantic, so hold on.
del
del
5000 Club
5000 Club
Images: 410
Postby del » Sun Nov 11, 2007 12:01 am
Today I woke up all excited because I was ready to put primer on the body, not to be, ####### wind. So i went out and worked on my subaru. It now has a new fuel filter, and is wired (mostly) for electric brakes, and charging. About 4:30 the wind died down, so after dinner I worked on the floor, for as long as I could stand the cold. Like my concrete gravity clamp?
Although I did not accomplish what I wanted to, I did work that was required for my trip.
del
del
5000 Club
5000 Club
Images: 410
Postby jdarkoregon » Sun Nov 11, 2007 12:48 am
Del,
I've been watching your build, boy, you sure took on a job! You are "getin R Done" and well too!
Thanks for keeping us all in the loop
John
Innovation is essential
The world can be better
jdarkoregon
Images: 47
Postby del » Sun Nov 11, 2007 11:13 am
jdarkoregon wrote:Del,
John
The build was alot more than I bargained for, if nobody was watching, I would have thrown in the towel long ago. So thanks for watching, and keeping me on the path I started.
del
del
5000 Club
5000 Club
Images: 410
Postby elmo » Sun Nov 11, 2007 11:43 am
John
del
I like it because it is very unique...keep up the great work. :applause: :thumbsup:
It's scary when you start making the same noises as your coffee maker.
elmo
Images: 216
