Weerider wrote:I am also interested in thickness used. I am curious as to whether most folks are using .032 or .040.
I think I am going to use contact cement just because I have lots of experience with it. Hopefully it will stick well enough to prevent oil canning.
Is aluminum sheet soft enough to trim with a laminate trimmer?![]()
Howard
jdarkoregon wrote:Steve,
Have you had any "oil-canning" with that adhesive? I guess my real question is, did any of the adhesive break loose with the movement of the trailer?
What thickness of alum did you use in your roof?
I'm finally getting near this same part of my build.
John
Howard
