nikwax wrote:the only criticisms I've read of exterior LED lighting is that LED's can be very directional compared to incandescent. Hopefully improvements in reflectors and lenses will change this.
jeep_bluetj wrote:A resistor devider used to drop 12v to 4.5v would be inefficient and offset any power savings the LED had. (i.e, all the current that goes through the resistor gets turned into heat). Better option is to recalc the current limiter resistor for the LED being used. (only one resistor)
Ken J wrote:Wondering - do LED's run cool - or do they get hot?
Ken J.
