Nice work, fenders sure look good with the same profile as the rest of the rig.
Galley looks purposeful (is that a word?) with the different sized cubbies, is the raised counter for hiding the campstove?
ChickenFoot wrote:Thanks Weerider, On the ac vent, there is a wall between the hot air and fresh air intake. I ran the ac on low all night, you could hang meat inside. We were at 82 degrees yesterday with high humidity around 80% the ac cycle just fine and there were no leaks. I got about a quart of water out of the drain line. I have plans on a solid door to close up the vent when not in use.
