Can you glass to aluminum?
Postby MSG Hall » Tue Nov 20, 2007 4:09 am
I’m kind of doubt’n it, the different expantion/contraction rates in the heat and cold would probably break the bond. But I thought I’d ask the experts… what do you think?
This is a boat project I have been thinking about. I would like to put a 3’ tunnel in my aluminum Jon so I can raise the motor.
{its Bruce to my friends}
camping and hunting knives custom made by a good friend of mine... www.sharpeknives.com/
MSG Hall
Images: 28
Postby SteveH » Tue Nov 20, 2007 7:50 am
Obviously, I have no experience with it, but I think it would work if you cleaned and ruffed up the aluminum at the joint, and used epoxy resin. If it came loose later, you could always seal the joint with silicone and rivit it back together if the glass is thick enough.
SteveH
SteveH
Images: 42
Postby madjack » Tue Nov 20, 2007 11:12 am
...you should be able to rough up the Al and use thickened epoxy...depending upon what you are using it for, I would recommend a mechanical fastener(rivets, etc.) as well............
madjack 8)
Postby mb82 » Tue Nov 20, 2007 12:27 pm
Depends on the usage of the boat. My buddy had a tunnel put into his jonboat so he could put his jetdrive up higher then the underside of the boat. That was about 5 years ago and with abuse the welds of the tunnel are coming apart so I am not sure fiberglass would work. By abuse I mean hey look at that class III rapid lets go up it. The boat has been drug across more rocks in the James River then I want to think about.
mb82
Postby Bad-Dawg » Tue Nov 20, 2007 3:42 pm
I have embedded all kinds of Aluminum objects into a fiberglass/epoxy matrix on several projects, and have used epoxy (Jb Weld and Marine tex) to rebuild Aluminum objects. Works fairly good but you may want to consider that this tunnel will have a lot of pressure on it so it will need a fairly large lap joint. It's certainly do-able.
B-D
Bad-Dawg
Bad-Dawg
Images: 11
Postby angib » Tue Nov 20, 2007 4:51 pm
The epoxy to aluminium bond is good but I second bad-dawg's comment about the size of the joint. Also no adhesive copes well with peeling forces, so the joint design needs to avoid that.
While I think of it, it may be worth adding that the epoxy to stainless steel bond is awful and nothing that I know of will make it any good.
Andrew
angib
5000 Club
5000 Club
Images: 231
Yes, Yes, Yes
Postby HossHoffer » Tue Nov 20, 2007 7:24 pm
The definitive answer is a resounding yes. Glass works very well on aluminum. We do many repairs on aluminum parts with fiberglass in the aviation industry. The bonding surface should be sanded clean and is often prepped with phosphoric acid. I would add however that in an engine mount application fiberglass does not make a good hard point (if I understand correctly that you plan to mount the engine on the tunnel) and you would have to engineer some metal reinforcements for that.
HossHoffer
Images: 7
Postby Alphacarina » Wed Nov 21, 2007 10:06 am
Epoxy to (roughened) alumunum would make a good bond - If you're wanting to use polyester resin (common fiberglass) I would drill a few dozen small (1/8th inch) holes in the aluminum where ever you can to increase the strength of the bond
Don
Alphacarina
Postby glassice » Thu Nov 29, 2007 1:31 am
Maybe we use ALU for molds . no matter what you do you can make it pop .you need to mechanical tie it down small holes pop rivets
It is not the return ON my investment that I am concerned about; it is the return OF my investment
glassice
