How thick or wide should the wood strips be? And how many would I need to start with on a 4 x 8 foot tear?
Looks like I may be getting a Woody
Classic Finn
toypusher wrote:Heiki,
I'm not so sure about you anymore. Talking about 'Strippers' and 'Woodys'!![]()
What next???![]()
prohandyman wrote:So, would it be improper to say that I have a stripper and a woody?
Sorry! Anyway, my wood strips are 3/16" off the saw, and after glue-up and sanding, they end up somewhere around 1/8". Now thats cut from 11/16" stock, so as you look at them glued up, they are each 11/16" wide, and it took 79 strips to cover one side. I think JuneauDave has used wider stock, so his strips are wider, thus it would take lees strips.
It all depends what wood you have available to mill, and if you prefer to plane them yourself. Most home centers and general lumber companies sell 1 by lumber, that is 1" thick stock milled (or planed) down to 3/4". So after cutting you would have 3/4 " planks on the tear. Divide your tear side height by 3/4 to roughly determine amount of strips needed.
For example, my tear sides are 54" high, and if I used 3/4 " lumber, I would need 72 strips of wood to cover the side.
A 48" tall tear would need 64 strips, 3/4 " wide.
Clear as mud?
Juneaudave wrote:I thought I remember a discussion or two about the different wood types in your neck of the woods and as I recall, there were some native species that would work very well. Not sure if its practical, but it would be interesting to see if you could find a small mill that cut up finnish wood. Seems I remember a Scots Spruce that would be nice, and some talk of the ash, elm and birch would make good accents and trim.
I ripped most of my wood from 2x6's (1.5 inches nominal). At 1.5 inch width per strip, that would give you 48 inches divided by 1.5 inches equalling 32 strips per side. 3/16 inch thick would be ideal. I would not hesitate to use some 2x nominal stuff from a local mill if a person could find it.
I can hardly wait to see what you can find!!!
