Painting aluminum?
Postby ssrjim » Thu Nov 29, 2007 8:45 pm
R. Maxwell wrote:Hey Ssrjim, I looked at you photos with my wife and that is exactly the way I was thinking of doing it. Matching body color with aluminum trim. Your trailer looks great. Nice matching pinstriping also.
Again nice job
Rich
Thank you.
93079
ssrjim
Re: Surface prep!
Postby HossHoffer » Thu Nov 29, 2007 10:58 pm
kurtibm wrote:The manufacturer-applied clear-coat on my 10 year old TD failed, so I am stripping it off.
What would the aluminum experts recommend as a wipe or brush-on corrosion-inhibitor?
Should I just leave it alone (it's mill finish) or treat it with something like ALODINE 1001? I don't want a 'coating' as such, where it may need to be stripped again, more like a 'treatment' or the like that would leave the surface sheen about like it is.
Thanks in advance,
Kurt
There is a clear alodine that doesn't leave the yellow/brown of regular alodine. It will help with corrosion but it will etch the surface so you would have more of a matte finish. That sharkhyde sounds promising though.
Hope this helps
Hoss
HossHoffer
Images: 7
