Thats It, hide your eyes - I'm going to strip!
Postby prohandyman » Fri Nov 30, 2007 4:02 pm
I'm thinking brown, or a tan color. I wonder how Luan ply, sealed and 'glassed might work???
I used (contrary to your sugeestion in the cd) 1/4" luan for the outer skin, instead of 1/8 ply. My bad! Had to use screws to hold, along with construction adhesive. So, I now have to coat the top with something other than clear to hide the screws. The luan does have a nice grain to it, but I don't have a choice now. Tan or brown would look nice. I'm stripping the front up to the apex of the curve,(first six strips glued up today) with a piece of mahogany trim running horizontal as a transition. And the sides will be trimmed in mahogany as well.
Pics to follow.
Dan
Dan
prohandyman
Images: 785
Todays progress
Postby prohandyman » Sun Dec 02, 2007 11:05 am
ImageDoors hinged and mounted temp
Image Front strips going on
Dan
prohandyman
Images: 785
Postby Juneaudave » Sun Dec 02, 2007 12:10 pm
Dan....In preparation for stripping the top of the SlumberMax...do you think you could get enough clamping pressure by running 4 or 5 tie down straps over the top? That was kind of my conceptual, not having been there.
BTW... that is looking really, really good. What a work of art!!!! :applause: :applause: :applause:
Juneaudave
Images: 380
Postby prohandyman » Sun Dec 02, 2007 1:30 pm
Dave
What would you connect the straps to? Would you make a lap all the way around the perimeter? Would have to be awful long straps! My guess is that the straps would have alot of stretch in them, but you might be able to add blocking between the straps and the strips , right where where you need the most pressure, to "shim" for a tighter hold! I've seen several builders on the forum use straps to hold ply down, but then again they don't have to put pressure evenly on multible strips. Steve Frederick uses a warped 2x4 under a strap to put pressure on his 1/8 ply! Might work here! :thinking: Love your tree ornament!
Dan
prohandyman
Images: 785
Todays progress
Postby prohandyman » Sun Dec 09, 2007 11:06 am
Sink in and cabinets framed
Dan
prohandyman
Images: 785
Front
Postby prohandyman » Tue Dec 11, 2007 4:26 pm
Finally got front epoxed
Dan
prohandyman
Images: 785
Postby WarPony » Tue Dec 11, 2007 6:41 pm
Dan, can you show how you finish the edges?
Jeff
WarPony
Images: 289
Postby Jst83 » Wed Dec 12, 2007 5:19 am
:beautiful:, I'd love to get a sneak peak early if I could
Jst83
Images: 215
Postby prohandyman » Wed Dec 12, 2007 5:27 am
sneak peaks available daily! Its at hangar 18, area 51, so I will have to blind fold you to take you in! High security 8)
Jeff
I will take a few photos today, but I'm going to make edge trim for it to cover edges though.
Dan
prohandyman
Images: 785
Postby prohandyman » Wed Dec 12, 2007 12:21 pm
Jeff
I don't know if this pic helps or not. Corners rounded, nail holes will be covered with trim, then more epoxy!
Dan
prohandyman
Images: 785
Postby Jst83 » Wed Dec 12, 2007 5:26 pm
prohandyman wrote:sneak peaks available daily! Its at hangar 18, area 51, so I will have to blind fold you to take you in! High security 8)
Jeff
Does that mean I'd need some kind of special clearance
You forget we know where you live Image
:lol:
Jst83
Images: 215
Postby prohandyman » Wed Dec 12, 2007 9:47 pm
No special clearance needed. Let me know if you want to stop by.
Dan
prohandyman
Images: 785
Postby Jst83 » Wed Dec 12, 2007 9:52 pm
:thumbsup: I'll do that here soon I'd love to see the expoy process
in person
Jst83
Images: 215
Ready for trim!
Postby prohandyman » Sat Dec 15, 2007 3:13 pm
Finally, stripping and epoxy are done! :applause: Ready for trim and varnish! Steel fenders are temporary until funds are appropriated for fiberglass.
Dan
prohandyman
Images: 785
Postby Miriam C. » Sat Dec 15, 2007 6:48 pm
:applause: :applause: :applause: :thumbsup: :P :beautiful: :woohoo: :awesome:
Congratulations Dan
:thumbsup: You have created a piece of art for sure. Now get out and :Flippin Burger: :campfire: :picnic: :relaxing:
