Ken A Hood wrote:And the million dollar question: how much?
The black goo is available everywhere and relatively cheap........
Ralf wrote:When I crawled under an RV to check out the axel I noticed that fabric covering the bottom. It did not look very sturdy but I will take your word for it. I guess they wouldn't use it if it didn't work.
Steve_Cox wrote:Hello Newguy with big plastic sheet to wrap his floor.
I can tell ya why I don't like that stuff. I've seen a few travel trailers with a soft , delaminated plywood floors, and they have all been wrapped in a plastic sheet. One had a leaky shower and the plastic didn't let the water drain out. one had a leaky door seal, and the plastic didn't let the water drain out and the last had a leaky water tank under the bed and the floor fell apart, good thing it had the plastic there to catch the pieces![]()
I like my plastic roofing tar coating since it became part of the floor and not just a place to gather water that has made it way through or around the floor. I also coated all my plywood with epoxy to make it waterproof and put foam board insulation under the trailer floor.
Trailers are a lot like boats in two regards. You need to keep the water out and if it gets in you need to get the water out. Try getting water outta that black plastic bag......
