plumbing questions
plumbing questions
Postby nikwax » Sat Dec 15, 2007 8:11 pm
I've just installed a sink and hand pump in the emerging galley, I have a couple of plumbing questions/needs:
I need flexible drain hose for the sink. It has a standard fitting on the bottom so 1 1/2" pipe or hose, or of course it could be reduced down. Any suggestions here?
I will need a couple of gray water holding tanks, say 5 gallons each. I'm seeing rigid:
http://www.pplmotorhomes.com/parts/rv-t ... /20517.htm
and collapsible:
http://www.racersrvstuff.com/racersrv/d ... EM=4416018
thoughts here?
nikwax
Images: 30
Postby madjack » Sat Dec 15, 2007 8:36 pm
....yes Nik, they make the tanks in 5gal and up sizes...they also make a drain fitting for your sink that forms a "P" trap with a regular hose fitting on the side of it...should be available from RV supply houses....
madjack 8)
Postby nikwax » Sun Dec 16, 2007 1:11 am
thanks MJ, that's the part I do know. I could use specifics with the plumbing and experience with the holding tanks ;-)
nikwax
Images: 30
Postby prohandyman » Sun Dec 16, 2007 5:34 am
Nik
I was thinking of something like this. It's an automotive drain pan.
Might be adaptable :thinking:
Dan
prohandyman
Images: 785
Postby Randy77301 » Sun Dec 16, 2007 5:58 am
I had used a blue plastic jerry can for my gray water when I had my pop-up,, I used a piece of garden hose and ran it from the outlet on the side to the can, approx 3 feet long. It worked well for several years..
Randy77301
Re: plumbing questions
Postby bobhenry » Mon Dec 17, 2007 9:51 am
[quote="nikwax"]I've just installed a sink and hand pump in the emerging galley, I have a couple of plumbing questions/needs:
and collapsible:
thoughts here?[/quote] 15 FEET 0F 4" PVC WILL HOLD 10 GALLON.
A couple 7' runs manifolded together and installed on the underbelly of the tear. Use a couple of tees and a tee down to a hose bib for a drain. Tee in a connection up top from the sink drain line and there it is. Should be way cheaper than the 60 bucks they want for the 10 gallon dump.
I hope to install a 12 gallon potable water tank in the same manner!!
The grey water tank above will be installed also totally independent of the potable storage to avoid any problems.
Users browsing this forum: GrandpaLarry and 8 guests
