Size of Pop-up frame?
Postby Michele » Wed Dec 26, 2007 8:26 pm
I found an add for someone selling a pop up camper for $50. The owner wasn't able to give me much information about it. She was only able to tell me that it is a 1989 Starcraft but nothing about the dimensions. The camper is still on the trailer so I don't know if I will be able to see the frame. I was wondering if anyone that is familar with tearing down pop-ups could take a guess as to what size the frame might be. :worship:
Michele
Images: 120
Postby bobhenry » Wed Dec 26, 2007 8:45 pm
Ya can't buy the reciever and the safety chains for $50,00 Bucks. Most pop ups are 5x10 or 6x12 why grumble. A frame will cost you $350.00 to $500.00 bucks. Ya might get some goodies inside GO FOR IT. If it don't meet your criteria build one for the masses , sell it and build the chosen one. I guarantee you what you learn will be well worth your time.
Somebody is wispering in your ear.........
Postby angib » Thu Dec 27, 2007 7:06 am
I've done a few drawings of (larger) teardrops to go on pop-up frames and one thing to note is that most of them are quite wide and it can be quite hard (read, nearly impossible) to narrow them down.
So if you want a 78" or so wide trailer, the pop-up frame is ideal, but it you want to adapt it to carry a 4ft or 5ft wide teardrop body, you need to be good with a welder.
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby 2old2tent » Thu Dec 27, 2007 8:45 pm
Mine is on an older Starcraft, probably early '70's. The outside dimensions of the frame were 6'-3" wide by 9'-10" long.
It wasn't very hard to remove everything that looks like a pop-up once I made the decision to go TTT.
Jack
PS: My frame was exposed all the way around so measurements were easy to get before hand.
2old2tent
Images: 41
Postby Michele » Thu Dec 27, 2007 10:14 pm
Thanks for the advise. I purchased the camper. The frame is 6'3 X 13. It is perfect for what I want to build, a standie similar to the Puffin. I still can't believe they sold it for $50. They paid $350 for it 3 months ago. They thought they were going to repair it but they decided they didn't want to deal with it. Looks like there is a ton of stuff that I can use.
Michele
Images: 120
Postby 2old2tent » Thu Dec 27, 2007 10:20 pm
The Puffin was our inspiration also.
Steve did a great job of documenting his build.
Jack
2old2tent
Images: 41
Postby angib » Fri Dec 28, 2007 10:15 am
Michele, what a superb value buy! Those interior fittings are worth plenty more than $50 without the frame.
Here is a PDF of the Widget design modified to fit on a pop-up frame which may give some ideas:
http://www.angib.pwp.blueyonder.co.uk/t ... dget7b.pdf
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby Ken A Hood » Fri Dec 28, 2007 10:33 am
It's in better shape then the one I picked up for $200.00
LINK
And I think I got a good deal since all I really wanted was the frame....and when I tore it down thats all I could use. And it's a torsion axle, which I was going to go with if I had to build my own frame.
Disclaimer: I in no way resemble the avatar shown. Furthermore, I in no way have any affiliation to the Trailer Park Boys and more specifically Bubbles!
Ken A Hood
Images: 42
Postby Miriam C. » Fri Dec 28, 2007 6:06 pm
Wow Michele, what a great deal. If that looks as nice as that looks in pictures I think I might leave as much of it where it is as I could.
You can see what Dave and Kathleen did here
http://tnttt.com/viewtopic.php?t=17755
they left most of the sides in tact while I had to build mine from the bottom up.
Ours was already torn down but the resulting frame bed was 6'4" wide and almost 8' long. It made a great TD/TTT. ;)
Postby Michele » Sun Dec 30, 2007 9:04 pm
It only took one day of demo to reduce this pop-up to nothing but a plywood floor. The floor and the sides are rotten, full of roaches, and not worth using. However, I will be keeping the sink, frig, cushions, cabinet doors and lots of hardware.
Michele
Images: 120
Postby 2old2tent » Mon Dec 31, 2007 3:53 pm
Boy does that look familiar.
I fully intended to rebuild mine when I bought it. It was an early 70's I think and had a swing-out galley, called a Swinger 6.
The lift system was cable operated with a winch and had to be repaired just to get it open. We were able to use it once then started disassembly to rebuild the top, water soaked and must have weighed 500 pounds by itself. The more siding that I took off the worse it got. Rotted sides, ends and floor. That's when it became a flatbed trailer. I kept all the electrics, they all worked.
I did grind off the back bumper mounts and if (when) I put the bumper back on I'll fit it up tight to the rear frame rail.
That side plate (curb side) that the step hangs on I ground off also. I brought my sides down over the frame, I thought it gave a more proportional look.
Good luck
Jack
2old2tent
Images: 41
Postby Michele » Tue Jan 15, 2008 8:53 am
In case anyone is interested, this is what a pop-up frame looks like once the camper is removed.
Image[/img]
Michele
Images: 120
Postby Catoosa Grani » Tue Jan 15, 2008 12:32 pm
Several years ago we bought a pop up for our kids to use when the grandkids were little. Well, they used it very little and have just let it sit and, (I am sure, fall apart). Well, to make a long story short, we are going to get it back and see what the damage is and what we might be able to build on it. It was a nice pop up and I really am disgusted with them for not using it. They like to camp but want all the comforts of home I am sure. It had a lot of the comforts when new. Oh well, now we can play with it and try our hand at building a TD. I am excited to see what we can do.
Grani
Catoosa Grani
Images: 86
Postby packerz4 » Tue Jan 15, 2008 1:11 pm
how exciting! i'd definately use a pop up frame again... though i didn't build mine from scratch... check out my album!
have fun!
tk
8)
~ Go Packers! ~
www.2bagalot.com
packerz4
Images: 53
Postby bve » Tue Jan 15, 2008 7:58 pm
packerz4 wrote:how exciting! i'd definately use a pop up frame again... though i didn't build mine from scratch... check out my album!
have fun!
tk
8)
Hey Packerz, I've been looking at your rig, and I'm wondering how it was pulling it behind your Jeep? Does it have much of an effect on MPG, given it is about 12"-18" wider?
Burke
KISS > COMPLEX
Build threads converted to PDFs.
As of 2008-08-08 I have added more build threads to the pdf collection
bve
Images: 98
